My new build (6750, 8800GTS, P35-DSR) can work fine, but invariably screws up, running Superpi at 41 s, rather than 19s, and getting 3dMark scores around 4000. A system reset fixes this, but the problem comes back. What could be causing this? It gets very irritating having to system reset to play games decently. I don't know what happened, but the first two times this occurred, the program compatibility assistant came up and informed me something had not installed correctly.
I have Vista, if that helps.
