Case pc & cooling help.
December 1, 2012 1:48:13 AM
hi i want to buy a case for my pc not less than $ 100 / us, which you want to install a corsair h100, but I will not be very expensive. But you have or can you install multiple fans for future expansion, so that is always fresh inside I have a
MB ASUS GENE V
I5 3570K
CORSAIR Vengeance 16GB
WD 500GB
as this processor is very hot on occasion reaches 60 ° I used 100% and the fan noise is unbearable, I wonder if you could put the h100 fan of silent to make less noise.
More about : case cooling
