Yes No
Ads
Tom's Hardware > Forum > Overclocking > CPUs > Temperature Guide Question
Forum Overclocking : CPUs Temperature Guide Question
I noticed that the b3 q6600 values have changed since I have last read them. I'm alittle confused as to what temps are correct, the new 1's or the old 1's.
If the new ones are, then I have set up my rig for temps too high for my processor.
I video encode alot and my cores frequently reach 60c while using Main Concept Encoder, 50 to 58c while gaming, and I prime to 65c
Did I do any damage to my processor running at these temperatures?
Thx in advanced
Message edited by deranged on 03-14-2008 at 01:48:10 AM
Reply to deranged
I'll leave Compu to explain it all, but you're fine. Under 65C is all good, the B3 Intel recommended specified max temp is around 62C, so it's fine really.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
Thats cool (well not literally), I'm always thinking this little guy is going to fry on me.
Reply to deranged
deranged, just as Evilonigiri suggested, your temps are fine. The changes to the Guide reflect new information for Tjunction (Core temps) which means that your Core temperatures are actually cooler than what is being indicated to you. As for Tcase, there are no changes. Please review the Guide again, with particular attention to the Findings in Section 5. Also, I recommend that you work through the Calibrations in Section 9, which is now simplified, so that you're confident Tcase (CPU temp) and Tjunction (Core temps) are both accurate.
Let me know how it goes,
Comp :sol:
Message edited by CompuTronix on 03-14-2008 at 09:16:15 PM
------------------------------ i7 920 C0 @ 4.1 - 1.375V | CPU 63C - Core 68C @ 22C Ambient | Xigmatek HDT-S1283 Dual 77CFM Fans | Asus P6T Deluxe | G.Skill 6GB DDR3 1600 @ 8-8-8-21 | 3 VelociRaptor 300 RAID 0 | BFG GTX 280 @ 670 & 2550 | Antec 900 | Corsair 650W | 3DMark Vantage 15,091
Reply to CompuTronix
Ok sounds good, I will read it again and thx for the reply
Reply to deranged
Let me know if you have any questions. Also, since this update was quite extensive, I would very much appreciate any observations or suggestions you might have.
Thanks,
Comp :sol:
There are 1913 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this be a good build to overclock 2500k to 5.0GHz?
By DJDeCiBeL, 14 hours ago:
I'm the one that told him that a Silver Arrow will get to 5Ghz, so I'll take the blame...
Best offers
Top experts
