New System Shuttle SP35P2pro bios problem. Please help!
kumar16
This is my first attempt in building a new system. I got the Shuttle XPC SP35P2 Pro. Here are the specs:
- Intel Q6600
- 4 GB (4*1gb) OCZ Platinum rev 2
- Maxtor 500 GB Sata
- Samsung IDE dvd-rw
- geforce 6800
When i try to boot the system, with the windows cd inserted into my IDE dvd-rw, it goes to this screen
"Jmicron PCI-IDE/... controller......http://www.jmicron.com
ODO0: samsung
press any key to continue"
I cant get past this screen.
So, i try removing the IDE cd rom and set my SATA hd as the first boot device and it goes to this screen
detect drives done, no any drive found"
I did some research and people have told to disable to jmicron controller. There is no place to disable this in my bios (altough i disable all IDE devices).
I have tried booting with 1 memory stick installed at a time, no changes.
Here is the link to the bios manual: http://global.shuttle.com/servlets/download?file_id=9748
I am new to this, so any help is greatly appreciated.
cfvh600
993
Try swapping the cable of your cd rom with the one from your hard drive, and set the first boot device to be your cd-rom. Dunno if that will help.
