I have a machine I built aprox a year ago:
Core2duo 6300, AsRock mobo775Dual-Vsta
2x512 simpletech ram, an AGP 6800GT GeForce Graphic board.
Recently it started developing some problems. Booting slowly then normal,
some freezing or crashes. In th e last few daysthe computer was starting loading the Os and freeze.
Switched the memory, same result.
Now it is not possible to use it anymore.
I formated the HDD, reinstaled windows, got some issues doing that, so I reformated again, installed
Ubuntu Linux. It works but very slow. After some tests and exchanging hard drives I decided the problem is not from the HDD.
It run MemTest but freezes at 96% first time then at 65% second time, and it do not started again until next day.
Also something else hapened, an USB mouse and an external HDD conected to the computer stoped working, even in another computer. I belive it is an related issue.
After this event I belive is something bad going on with the motherboard, but I dont have finances to just go buy one and try a new mobo and a new CPU.
Please advise how I could check more and what you belive is the problem.
