ok i need help with a new system i bought...by veloctiy model: promajix E2035.
well the problem is...im unable to connect to the internet with it. I using my old pc right now to do this. I use all the new wires except the ethernet connection. It works fine here but when I pop in the ethernet into the new pc it just wont connect. cany anybody please help. I called GeekSquad which was **** ghetto...they kept trying to send someone down to the house...i was like NO. They didnt want to help. only way they were willing to help is if someone was sent over to my house. which is $100 just to determine the problem..!! WHAT!? lol yea...but please if you can help it will be greatly appreciated.
------------------------------Microsoft over Apple anytime!...To much hype on all the apple products (especially the iphone and ipod)
More information required :
1. Is TCP/IP installed on your new PC.
2. How is your network configured.. I am presuming all your PCs connect to your router. In that case are the PCs configured for Static IP or dynamic IP? If dynamic IP then is you new PC configured to get IP address automatically.
3. can you ping your router from the new PC
2. Im not using a router im using a modem...I have cable. ethernet.
and im using it right now with my old pc in order to ask you guys for help...the cables im using right is the cables it came with...if i connect all the wires the same way with the new pc it wont connect to the internet.
sorry if i made this even more confusing..
Message edited by suspenz on 11-14-2007 at 06:31:40 AM
Reply to suspenz
Ok here what you should do
First lets see how your working/old PC is setup
1. Goto Control Panel --> Network Connections. Here you should see something like "Local Area Connection" with status as "Connected". Right Click this and select Properties. In the windows that pops us select "Internet (TCp/IP)" and choose properties. Here copy down all the options that have been set as this is what you have to setup in your new PC.
2. To check if TCP/IP is installed in your NEW PC goto Control Panel --> Network Connections. Here you should see something like "Local Area Connection" . Right Click this and select Properties. In the windows that pops us ensure that "Internet (TCp/IP)" is ticked. If not tick it and choose install
3. Once you have confirmed that TCP/IP is installed and ticked. Select it and choose Properties. Here ensure that the values set are the same as that in your OLD PC.
4. Now try to ping the Router/Cable Modem.
If it doesnt work then tell me what the settings are in your old PC and we will take it from there
my new pc is vista not xp...so can anybody help me...i alreayd tried what i was from above...i hit install but it says "clinet", "protocal" and something else forgot...i hit instal on protocal and another windows pops up...it doenst give me options but one that says "have disk"....please help
new pc says i have two versions...tcp/ip...what does they both do?
Message edited by suspenz on 11-14-2007 at 09:05:04 AM
Reply to suspenz
lets start again. In your old PC (is it vista or XP) can you give me the output of the following command :
ipconfig /all
Also tell me what is set for the following:
ipconfig /all
In case it is vista use TCP/IPv4
my old pc is xp...only thing is im at work right now...so ima go ahead and do this tonite when i get home....only thing is when i go on my old pc and go to the properties...it doesnt have two versions...all it says TCP/IP and thats it...new pc have version 6 and version 4...as i see you said version 4 ..ok...now i know what im looking for... when i go to the properties(tcp/ip) in my old pc nothing comes up...you know what before i make it more confusing...let me do connect my comp tonite and see what i come up with....sorry for the confusion...ill bbl.
Thank you for all your help.
Reply to suspenz
hey i got it man.....i called my cable company and it was simple..thanks anyways...i appreciate your help. I guess no one else cared but you...lol. Have a nice night. Thank you!
Reply to suspenz
