Final build before order - need opinions on minor tweaks.
Basically , because im a worrying perfectionist , I need the backup of opinion and knowledge that the components below will all fit together to make a whole computer - without OS.
Also , I would like to know if in the future - this would be able to handle adding the following -
1. Another 8800Gt Nvidea
2. Another 2Gb of identicle RAM
3. TV tuner.
CPU - http://www.ebuyer.com/product/131950 Intel Quad core 2.4
GPU - http://www.novatech.co.uk/CPU - http://www.ebuyer.com/product/131950 Intel Quad core 2.4
GPU - http://www.novatech.co.uk/novatech [...] ?ASU-88GT5 Nvidea 8800 GT 512MB
RAM - http://www.ebuyer.com/product/98710 Corsair 2GB kit 800mhz Ram
HDD - http://www.ebuyer.com/product/124228
Case - http://www.ebuyer.com/product/127584
CD/DVD - http://www.ebuyer.com/product/129527 SATA dvd/cd drive
Mobo - http://www.ebuyer.com/product/131173
PSU - http://www.ebuyer.com/product/127861 Stealstream 600 W
Sorry about being so irritating. Also if possible - if you know any good guides on how to build a computer - would you be so kind as to give a link?
6 answers Last reply
More about final build order opinions minor tweaks
  1. That motherboard won't support a second 8800GT.
  2. The Corsair is kinda expensive. These are cheaper & about the same:
    http://www.ebuyer.com/product/129954
    http://www.ebuyer.com/product/116755
    For the SLI mobo (2 x nvidia cards). 650i is the budget one. 680i is the best o/c'er:
    http://www.ebuyer.com/product/125082
    http://www.ebuyer.com/product/132812
    Stay away from the XFX 680i as some people have reported the board generates a high-pitch noise while surfing the Web. It doesn't come from the fans.
  3. Final Build before I order this afternoon - panic sets in.
    RAM - http://www.ebuyer.com/product/129954 New Ram
    Mobo - http://www.ebuyer.com/product/125082 New Mobo
    Can someone just put my fears to rest that it all goes together? and what are the limitations of the Mobo?
  4. Looks very nice, however if u want to OC then get a DDR2 800 RAM with
    4-4-4-x or lower timings
    ASUS P5N-E SLI is an awesome board, SLI support +1333MHZ CPU support
    + 45nm (Penryn) support
  5. Might wanna get something to cover the naked southbridge on the mobo.. u OCing?
  6. I'm not sure if the 600w psu can power 8800gt x 2. Some members here would recommend a 750w or higher.
    http://www.ebuyer.com/product/128212
    http://www.ebuyer.com/product/125620
    http://www.ebuyer.com/product/129282
    The Antec 850w is pretty good both value & wattage-wise. It's overkill for that sli build, but will last a long while.
New Build Systems
