Tom's Hardware > Forum > Storage > DVD/CD Writers > CRC problem with 2 different burners
Forum Storage : DVD/CD Writers - CRC problem with 2 different burners
Hi,
I'm having a big problem burning media for a couple of weeks now. Here is the full story:
I purchased a new DVD burner (ASUS DRW2014L1T) ago after my old LG rubber got cut.
I installed it, connected it to my SATA extension (the old one was on IDE).
After using it a couple of times, I started experiencing burn failures time & time again (DVD+R & Duals as well), most reffered with a "Cycling Redundancy Check" to certain files.
I uninstalled the Nero 7 I had and installed Nero 8 I recieved with the burner, along with Lightscribe ware hoping this was the problem. It wasn't.
After being told to try a different media and seeing it's not the problem, I contacted the store and had it replaced to a new one (same).
Installed the new one again, and got my hopes shattered again.
Finally, I decided to try the same content I was trying to burn on dual on a my friend's computer, to see maybe it's a physicall problem with my computer and it was burned successfully to my delight (confirming it's not a problem with the burner).
Although I have 2 SATA extensions on my motherboard (SATA ver. 1), one connected to HD, and the burner is suitable for SATA 1, there was seem to be a problem. We decided to switch burners temporarilly for now, until I upgrade my computer and I got his LG (Dual on IDE, no Lightscribe).
I've burned with the LG a couple of discs successfully over the weekend and to my suprise, recived the same CRC error yet again.
Some info i'll add:
*On the device manager, the IDE controllers, both Primaty IDE Channles are on DMA (first on Ultra DMA 5, the other is on Ultra DMA 2). No PIO's.
*On the BIOS, the first HD is master, second HD is slave, and DVD is secondary master.
*2x512 of RAM
*Both burners were connected alone to the free power cable (nothing on it besides the burner, to avoid transfer problems).
*Not sure if helpfull, but I upgraded my XP to XP PS2 (although it was a little before the first burner died so not sure if it's related in any way).
Would appreciate any help.
Thanks!
Sponsored Links
There are 671 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
