We all know that 2.5 inch drives consume less power than their 3.5 inch counterparts because the platters of the latter are bigger and heavier to spin. What about data transfer speed? if both the 2.5 and 3.5 inch drives spin at 7200rpm and both are SATA 300 drives, are their data transfer speeds the same? I would even think that the 2.5 inch drive would be even faster because of the shorter distance the readhead has to go to get to the data on the platter. So if 2.5 inch drives are faster and if capacity is not an issue, should I just install 2.5 inch drives in my desktop to get the performance boost and with less power consumption?
