Hi everyone, after much waiting to see how the amd phenoms preformed, I decided to go a quad core intel system, the only issue now is I have never set up a intel system in my life, always been AMD, but they let me down with long waits, over priced phenom, and under preforms compared to core2 clock 4 clock, so I abandoned AMD now until the can proove a better preforming product .
so my delema is I dont understand all the bios settings about ratio, vanderpool?? what is that??
if someone could run me through an optimum setup, im not keen on overclocking , but wana get it running sweet
cpu spread spectrum, fsb spread, dram spread, what are the best options for these?
what is c1E support?
cpu tm function
vanderpool technology
execute disable
max cpuid value
intel speedstep
also I installed the inf chipset utility, and I look on the intel site and I see , application accelerator, storage controller ect, do I need all of those as well? do they make it faster?,
sorry for all the noob q's but hey ya gotta learn sometime
I also found there was a few options for the way the HDD are used, 1 being IDE mode, the other is Raid, the other is ahci, which is best?, I dont raid drives (I know what raid is)
setup is
core2 quad q6600 G0slacr
asus p5E X38 chipset
2 gig corsair 555 12 ddr2 800 (i have some kingston hyper ddr2 1066, but it keeps crashing at reccomended volts and timings, so i say thats DOA)
2x seagate 32mb cache drives (absoloute beasts)
and thats about it, so if someone could help me understand the bios, a bit better, as the manuals dont help you at all, I would really appreciate it alot guys
also is anyone having issues running sata burners on intel systems? I had a pioneer sata running fine on my AMD system, but now in my intel one wont work, its detected in bios, power is on, but it wont read discs at all, anyone have the 4 11 on this?
Cheers in advance
Stuy
8800GTS
cpu tm function
execute disable
max cpuid value
intel speedstep
setup is
Cheers in advance
Stuy
8800GTS
