This brand new 640 GB Hard drive that was involved in the computer shutting down during windows vista installation is now making car revving sounds and displaying a red led blinking light at the front of the case...It is also blinking orange on the motherboard where the SATA cable goes in... I am not able to boot to windows, it just sits there and loads and then eventually turns off.
Is there anything I can do to save it or is this thing pretty much screwed?
PS. I don't care about backing up any files.
Thank you
Thank you
