Power/Watt Usage Monitor
  • Power Supplies
  • Monitors
  • Power
  • Components
  • Product
Last response: in Components
November 25, 2007 6:45:37 PM
Is there a device which I can plug into the wall and than plug my power cable from my power supply into so that I can get a reading of how many watts and amps my computer is drawing from the wall?
I think I've seen something like this before but not sure what it may be called or where I can purchase it.
Thanks in advance.
More about : power watt usage monitor
November 25, 2007 7:37:32 PM
Thanks in advance.
I use this one:
http://www.newegg.com/Product/Product.asp?Item=N82E1688...
November 25, 2007 11:46:53 PM
That's good! Thanks for the link badge.
Is there a way I can calculate the amount of power (in Watts) that a component is using simply by knowing the amount of volts it requires?
(P = V x I).
November 26, 2007 12:29:14 AM
(P = V x I).
The easiest way to do that would be to use a DC clamp ammeter. This, along with a unit like the kill a watt, allow you to see total and component power consumption. It's what I use.
November 26, 2007 12:52:04 AM
(P = V x I).
P = V x A
You need to multiply volts times amps to get the total wattage.
The volts is usually the first thing mentioned on a label on a device, the amp rating is sometimes missing.
You could just use what joefriday said to get the actual reading.
