Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-P35-DS3L restart problem...
Forum Motherboards & Memory : Gigabyte - GA-P35-DS3L restart problem...
I'm having a problem a with my GA-P35-DS3L motherboard and before I send it back I wanted to see if anyone knows what might be causing the problem.
I have an E2160 CPU and 2x1GB Crucial Ballistix DR2 800 w/4-4-4-12 timings. I had to change the memory voltage to 2.2V cause that's what the Crucial is spec'd at. I also increased the FSB to 266 and set the memory divider to 3 to run the CPU at 2.4Ghz. It runs fine until you try to restart it after it's been running for a while. Then it starts up for a couple seconds and then it turns off for a few seconds and keeps doing it unless I pull the plug on the power supply (turn off switch actually). After I pull the power and then reconnect it and turn it on, it will do the on/off thing a few more times and then it will boot up.
Sponsored Links
With your FSB set to 266, your memory DDR2 800 does not need set memory divider to 3. Try set mem divider to 2 (1:1), timing 4-4-4-12 and all voltages @ "auto" in BIOS.
Reply to Hien Nguyen
Probably a bad setup - to O/C, try changing one thing at a time, then testing. If it passes, repeat. If not, you know where the problem is.
Just because the RAM spec is 2.2v doesn't mean it needs it.
------------------------------ >< ))))º> >< ))))º> >< ))))º> >< ))))º> >< ))))º>
Reply to nhobo
Sounds like a bad overclock. You probably need to raise your Vcore. But you should do a search for a C2D overclocking guide and follow it closely. RMAing the board won't do anything.
Reply to orangegator
I have the exact same mother board and has my E2180 @3.2Ghz on a OCZ Vanquiser I bought for $10.
These are the setings I recomend:
Set "System Voltages" to "Auto".
Set the "Performance Enhance" to "Standard"
Disable "CIA2"
Set the "SPD" so that the result will be 800Mhz or less.
Set "DRAM DLL" to "Option 2"
Set the "CPU Host Frequency" to 266Mhz
Save and Reboot
http://valid.x86-secret.com/show_oc.php?id=282308
http://www.mediafire.com/imageview [...] lw&thumb=4
http://www.mediafire.com/imageview [...] dn&thumb=4
*Note these benchmarks were run before the CPU was OCed to 3.2Ghz. The results shown are at 3.05Ghz.
++PM Me if you have more specific questions on this Board.
Message edited by Shadow703793 on 12-16-2007 at 02:08:30 AM
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
If it runs fine stock theres nothing wrong with the board. I'd say read the overclock stickys again. That cpu should run 3.0 pretty easy with stock cooler even.
Reply to roadrunner197069
You are running Microsoft's latest trick, VISTA, right?
The problem you are looking for is not HW related. It is a pure MS VISTA thing. They tried to fix it with the hotfixes KB930261 and KB929777. But it didn't work out.
I have the same problem :( . I would like to downgrade to XP, but Microsoft won't let me. Too bad I paid for this crap.
Cheers
Paul
Reply to Paoluzzo
I have the same board and would not recommend setting the voltages to 'auto'. This is because the board always sets the voltages too high leading to higher temperatures. Instead maybe use 'auto' to take a peek at the voltages its automatically set to and work your way down.
Reply to dodian
If your computer is restarting like that something is wrong with your motherboard or PSU. Had the same exact problem twice. Once was the PSU, the other time it was unfortunetaly the motherboad...just replaced GIGABYTE DS3R with cheaper DS3L till replacement comes.
------------------------------ Q6600 @ 9x333, 500gb barracuda 7200.10
Gigabye DS3R P35, Evga 8800 gt
4x1gb Super Talent 800 3-3-4-8, OCZ 850w, Win 7 64
Reply to cory1234
Replaced the motherboard, problem fixed... Thanks to all that replied...
{DCR}MADMECH
Reply to MadMech
Is this a sign of a bad board? My computer won't restart - and wouldn't - until I overvolted the FSB to +.1.
Now it restarts just fine. It's a rev 1.0 board - and my warranty will probably expire in the next month or so - thing I should replace it?
Message edited by branflaks8 on 05-03-2008 at 12:27:42 AM
------------------------------ Gigabyte P35-DS3R | e6550 @ 3.11Ghz (445x7) | 4GB Kingston Hyperx 1066 | EVGA NVIDIA 8800GTS 320 @ 645/1000
Reply to branflaks8
There are 1037 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
