Tom's Hardware > Forum > Storage > General Storage > Help making my document and settings folder in another drive
Forum Storage : General Storage - Help making my document and settings folder in another drive
Okay well i am going to install two 32gb raptors in raid 0 for os/apps and I want to put my docs and settings on another drive. How would I go about putting them on a seperate drive
------------------------------ Antec 900 | EVGA 780i | E8500 @3.16 | 8500GT in SLI | OCZ 4GB DDR2 800 | OCZ GameXStream 600w | Seagate 250GB
Sponsored Links
In windows xp you can click start, right click documents and use the move button or type in the new location. However you cannot move your desktop folder.
I can't tell you how to do it in windows vista. I'm not sure it's even possible.
Reply to PsyKhiqZero
Ill see if it does the same in Vista because im using vista 32-bit home premium
Reply to Shawnhath
There are 575 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
