Help plz
Hello,
hi
whenevr i am trying to connect a internet dongle in the PC
it says PnP driver not found
Problem Event Name: PnPDriverNotFound
Architecture: x86
Hardware Id: USB\VID_201E&PID_2009&REV_0000
OS Version: 6.0.6002.2.2.0.768.2
Locale ID: 1033
i have tryied my level best to find the driver for this error
can you plz help me on this and can you plz send me the link as frm where i can download the driver
my email id is Shahidmax7@yahoo.co.in
Regards
Shahid
+91-9899648406
2 answers Last reply
More about help
  1. Did you install the drivers for the USB card before you plugged it in? Quite a few want you to install drivers first then connect the drvice. Try running updates to Vista also if you have not.
  2. shahidmax7 said:
    Hello,
    hi
    Architecture: x86
    Locale ID: 1033
    Regards
    Shahid
    +91-9899648406
    If all you need is the driver you can use Driver Navigator to find it
    Driver Navigator scans your computer for any missing drivers
    Go to http://www.drivernavigator.com/ for a trial or to buy it
Drivers Windows Vista
