Tom's Hardware > Forum > Homebuilt Systems > New System Build > New System build Advice please
Forum Homebuilt Systems : New System Build - New System build Advice please
Hi guys this my first post in the forum
I have a system about 6 years ago final i made my mind to get a new one build
I need some advice from you this what i have put together I am planing to spend around £1000 max for just the Box.
I think is a good amount to spend.
I am planing to use it mainly for 3d work and rendering scenes and sometime games. I was thinking SLI but i dont think I will get any more power if a get 2 low end card. Is better to go with a single good one and get a second one in the future when prices drop.
The system will run on Win XP PRO x 64bit
I am think about overclocking but is something that I have not done before. I know that Q6600 can be overclocked well.
Here is what I am thinking
2 x Western Digital Caviar SE16 500GB SATA2 16MB 7200RPM (RAID 0)
Antec Nine Hundred black miditower, Side panel window
Asus P5N32-E SLI, nForce-680i SLI, ATX, Socket-775, 2xGbLAN, DDR2, 2xPCI-Ex16
ASUS Silent Knight CPU Cooler, Blue Light, Socket 478/775/939/940/AM
Intel Core 2 Quad Q6600 2.4GHz Socket LGA775
LG DVD±RW burner, GSA-H62NRB, SATA, Dual, Black and White
OCZ Platinum DDR2 PC6400 4096MB KIT, w/two 2048MB PC6400 XTC, CL5-5-5-4
Thermaltake Toughpower 850W, Modular, 8xSATA, ATX/EPS, 4xPCI-E, 20/24pin
XFX GeForce 8800GTS 560M 320MB XT GDDR3, PCI-Express,2xDVI/HDTV/HDCP,560/1700Mhz
Any advice welcome I am open to suggestion.
Many Thanks
Chris
Message edited by Polygono on 11-21-2007 at 10:49:48 PM
Sponsored Links
Smaller power supply and get the 8800GT. rest of it's fine
------------------------------ It's a theater of love stories.
Reply to itotallybelieveyou
what size are you thinking?
Reply to Polygono
550W-650W. Unless you gonna SLI very soon then keep the 850W
well I am planning to make the system sli ready and get a second card as soon as prices drop. Well I looked for a 8800GT
XFX GeForce 8800GT 640M 512MB XT GDDR3, PCI-Express 2.0, 2xDVI/HDCP, 640/1900Mhz which only £10 difference
Reply to Polygono
Any more ideas people?
Reply to Polygono
There are 1099 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
