Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > PLEASE HELP! NO PICTURE!
Forum Graphic & Displays : Graphics Cards - PLEASE HELP! NO PICTURE!
I just installed a new GeFOrce 6200oc on an older cpu of mine, this is my first time dabling with video cards
I connected everything,fired it up and there was a msg in dos telling me insert my startup Xp disk
I shut it down and noticed that the HDD cable had come loose,
Reconnected, started it up and this time NO IMAGE....NOTHING!!!
I shut it down, re-installed the original Video Card, and again NOTHING!!!
The cpu is up and running but i have no idea what state its in.
PLEASE HELP!!
Sponsored Links
sounds like maybe you pulled a cable loose, try to re-check all connections. reseat the ram(it sometimes gets loose....i have seem it several times....)
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/26uxxb - C2/i7 Temp? http://tinyurl.com/cj3pw - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yfmxdc9 - Part Guide?
Reply to nukemaster
- 0 +
Do you hear any beep codes?
------------------------------ Quando Omni Flunkus Moritati
Reply to GuyAmI
Nope nothing, BUT good news, I tore it all down and reconnected slowly and tightly ad it appears to be working again.
I haven't installed the new card yet, but I will after a few tests.
QUick question if someone reads this:
I used Sandra to get me some specs on my motherboard, it is an old ASUS like 2001/2002 - It came with 512mb installed, and has two slots,
Sandra says it is 1gb max, - is that per slot or total. I picked up a 1gb stick - and Sandra shows all 1.5 gigs, but i'm not sure if the cpu actually uses it.
ALso is it better to have two 512mb or a single 1gb??
thanks again for the help
Reply to coryburgess
- 0 +
What model is your ASUS board?
As for 2 512MB sticks versus a single 1GB stick, Tom's Hardware actually wrote a good article about this question back in October: Dual vs. Single Channel
Reply to GuyAmI
There are 452 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
