Tom's Hardware > Forum > Storage > General Storage > Do I have enough power for internal HDD and stuff...
Forum Storage : General Storage - Do I have enough power for internal HDD and stuff...
My computer: HP a1750e with Athlon 64 x2 3800, 160gb HDD, 2GB ram, 8500GT GPU. Details here: http://h10025.www1.hp.com/ewfrf/wc [...] ct=3369460
My questions:
1) If I need to add storage space, can my current power supply handle another internal HDD? I've already added the GPU so I'm concerned about adding anything else. (the stock power supply is 300 watt)
2) What type of internal HDD would I need? I see a couple of types of SATA drives... how do I know which I'd need?
3) Is there anything I need to know about installing an internal HDD? Or do I just plug it in and boot up?
Sponsored Links
1) IMO, that's pushing it if you add another hard drive. I would look into upgrading it. 400 - 450 watts would be nice.
2) It has support for sata drives (up to 1.5GB/s). What size were you looking for?
3) If it's just going to be a storage drive, then yes, you can usually just plug it in and boot up.
br3nd064
Reply to br3nd064
I just want like a 500GB HDD.... what type of SATA do i need? Is it the 1.5gb? Or 3 gb?
How do I know what power supply I need? Are they generic? (Sorry... I'm a noob)
Reply to knottshawk
Honestly, you will not see any performance hit if you go with 1.5GB/s vs 3GB/s. Hard drives are not able to transfer data at either of those speeds, so it doesn't matter.
Check out this site for a general idea of what type of power supply you need: http://extreme.outervision.com/psucalculatorlite.jsp
If you find one that you like at an affordable price, post a link to it here and we should be able to tell you if it's a reliable brand that will work with your computer.
br3nd064
Reply to br3nd064
Well, the 1.5gb HDD's look to be harder to find and WAY more expensive... so can I use a 3.0GB with my system even though my primary HDD is 1.5gb?
Reply to knottshawk
Yes. Most sata 3gb/s hard drives come with a jumper on them to force them to operate at 1.5gb/s speeds. Unless you remove this jumper, you won't have any problems connecting one to your motherboard.
br3nd064
Reply to br3nd064
Cool... thanks!
Now I just gotta figure out the whole power supply issue!
Reply to knottshawk
There are 539 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
