Tom's Hardware > Forum > Overclocking > General Discussions > My system can't pass Prime95 on stock. Need help.
Forum Overclocking : General Discussions - My system can't pass Prime95 on stock. Need help.
My system wont pass Prime95 (Blend test) even on stock..
I got..
Asus A8N-SLI Deluxe
AMD FX-55 @ 2.6
2 gig DDR 400 RAM
I've had this comp for years now but now that I've started over clocking for fun I've realized my set up cant even pass Prime95 with stock speeds and timings. I can pass Small FFT's test after I upped the vcore a tad but I can't pass the blend test for the life of me..
I've tested my RAM with Memtest over night for 9+ hours and no errors. So RAM seems fine...
I've, like I said, passed small FFT's test so CPU seems fine... (Ran over night 9+ hours)
I've played around with vcore quite a bit.. Currently at 1.45 which is the voltage I pass Small FFT's at. I've tried upping it to pass the blend test but that just seems to be overkilling it and brings issues. At certain voltages my motherboard chip will jump up 10 degrees out of nowhere. (Using Speedfan for temp readings) Sometimes I can go even higher voltage and motherboard will jump back down to a normal temp increase of a degree or 2. So I dunno what the hell is up with that.
I mean, whats the deal here? I've had my machine for years now and its always run fine but I'd still like to try and help it pass this test.. Any ideas?
Sponsored Links
Passing Memtest does not guarantee ram stability. Rather, it guarantees that your ram is good.
Failing blend test is usually due to unstable ram, so tweak the settings around.
Message quoted 1 times
Message edited by Evilonigiri on 04-06-2008 at 07:02:17 PM
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
Yeah, try significantly underclock the ram, and run test to see if it's really cpu's fault.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
there seems to be some sort of issue with prime95 blend on some systems. Im having similar problems myself.
Reply to papasmurf211
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
