Power keeps shutting off
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power keeps shutting off
I have a strange dilemma going on with a cheapo EMachine Computer. It's a T2792 with a 2.8 Celeron processor and I have updated the power supply to an UltraV 500 watt unit. My problem is, it will shut the power off to the motherboard after running for a short time (seems to still have power in the PSU as the fan is still running on the PSU but the processor fan shuts off). I then turn the power switch off of the power supply and back on and the computer will power back up again and then repeat the shutting off problem. First I was thinking power supply, but it checked out to be okay (very basic test) and then I was thinking processor or motherboard, but I started it up into safe mode and it seems to run just fine and doesn't shut off. It seems then that power supply is indeed okay and that the processor and motherboard are okay, except for maybe one of the on board components is causing it such as the on board video, modem etc.? Any areas to look at and how should I go about trouble shooting and eliminating things until it will stay running?
Thanks
Sponsored Links
Go into your BIOS and check the power monitor, if you have one. One of mine has been doing the same thing and I see the 12V line is showing only 11.4V which is kind-of a 'lower-limit' for acceptable variance (5%)
I'll try replacing it and then I'll find out for sure. You may find something similar (or worse) on your machine... at least it's worth checking.
Hope it helps,
Message edited by dippytwitty on 12-02-2007 at 08:57:34 AM
Reply to dippytwitty
Id be incline to agree... The PSU sounds like its the main fault... have you got another one to test with?
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
How about paying your electric bill? :lol: I'm sorry I can't help myself when on pot.
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
How about some sort of power management setting that turns off the pc after a while? The OP mentions that it doesn't happen when he boots into safe mode.
Reply to cfvh600
Well I had the same problem once and found out that it was because i had a cheap PSU that did not have stable voltages.
Reply to joemamasmurf
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power keeps shutting off
There are 541 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
