Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > problem with some pages in ie explorer on xp pro
Forum Windows XP : Windows XP General Discussion - problem with some pages in ie explorer on xp pro
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi
In some pages in IE explorer - i get a small error message at the bottom of
the left side of the screen saying 'error on page'.
The page that I want to run is for my router set up and I am unable to
change settings that I used to be able to change here.
Does anyone have a suggestion about what I did wrong in IE to make this
happen and how to fix it?
Thanks
Doug
Sponsored Links
"gordon" <gordononline@optusnet.com.au> wrote in message
news:42db917b$0$30739$afc38c87@news.optusnet.com.au
> Hi
> bottom of the left side of the screen saying 'error on page'.
> this happen and how to fix it?
> Thanks
> Doug
Go to Tools | Internet Options | Advanced.
Check the box to Disable script debugging.
Uncheck the box to Display a notification about every script error.
Disable the Script Debugger in IE (Line 142) - Win XP
http://www.kellys-korner-xp.com/xp_tweaks.htm
1. You might want to refresh your scripting engine:
http://msdn.microsoft.com/library/ [...] webdev.asp
Windows Script 5.6 for Windows 2000 and XP
http://www.microsoft.com/downloads [...] layLang=en
Sometimes there's a corrupt file in the cache and one must go to Tools |
Internet Options and click Delete Files.
2a. Start>Run>Regsvr32 vbscript.dll
2b. Start>Run>Regsvr32 jscript.dll
(WinXP users who have problems with 2a and 2b, see
http://www.mvps.org/inetexplorer/answers_9.htm)
3. Re-register all DLLs listed in http://support.microsoft.com/?kbid=281679
4. See also
Error Message When You Browse the Web: An Error Has Occurred in the Script
on This Page
http://support.microsoft.com/?kbid=306831
Scripting Errors When You View Web Pages in Internet Explorer after
Installing Office 2003
http://support.microsoft.com/?kbid=822521
5a. IE Tools>Internet Options>Advanced>Browsing>Enable third-party browser
extensions (uncheck & reboot).
5b. Find the hijacker that caused 5a to be checked (or if none were checked,
check for hijackware anyway):
Dealing with Hijackware
http://mvps.org/winhelp2002/unwanted.htm
http://aumha.org/a/parasite.htm
http://www.mvps.org/inetexplorer/Darnit.htm
How to Troubleshoot Script Errors in Internet Explorer
http://support.microsoft.com/kb/308260
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/s [...] fault.aspx
http://defendingyourmachine.blogspot.com/
Reply to Anonymous
Thanks Frank
Could I send you the message that i get when I double click on the small
error icon (the yellow triange with '!')?
I have tried most of the solutions to the best of my ability but still no
luck.
Cheers
"Frank Saunders, MS-MVP" <franksaunders@mvps.org> wrote in message
news:uynff44iFHA.2156@TK2MSFTNGP14.phx.gbl...
>> Hi
>> Thanks
>> Doug
> 4. See also
> on This Page
> checked,
> Protect your PC
Reply to Gordon
>> Hi
>> to change settings that I used to be able to change here.
>> Thanks
>> Doug
> Tools | Internet Options and click Delete Files.
> 4. See also
> Script on This Page
> browser extensions (uncheck & reboot).
> checked, check for hijackware anyway):
Copy the words into Notepad and then paste them into a reply here.
Protect your PC
Reply to Anonymous
Thanks Frank
Here is the text in the error box (sometimes the char: appears to be
different - ie it varies each time).
char :1
error : object expected,
code : 0
URL:
http://10.1.1.1/cgi_bin/webcm?getp [...] var:rule=0
Thanks
Doug
news:%23ldTRdIjFHA.4000@TK2MSFTNGP12.phx.gbl...
>>> Hi
>>> Thanks
>>> Doug
>> 4. See also
>> Script on This Page
> Protect your PC
Reply to Gordon
There are 1128 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
