Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » new cooler issue -> is this normal??
Add a reply
 Word :   Username :
Bottom
Author
 Thread : new cooler issue -> is this normal??
Profile: stranger
More Information
Hi all!
I've just returned from my computer dealer who built in a Zalman CNPS9700 NT CPU cooler on my system.
As you can see on the picture, the fan and the heatsink are not parallel. The picture shows that the left side of the fan is higher than the right side.
http://home.scarlet.be/~gb070593/IMG_0313a.jpg
I noticed this because when I first booted my computer, I heard a rattling noise from the CPU cooler as well. I could fix this by slightly changing its orientation.
So what are your opinions on the fan/heatsink not being parallel? I this something I have to complain about to my dealer?[/img]
Related Pr oduct
Noob? Currently on Sabbatical!
Profile: Honorary Poster
More Information
Just check to make sure its pressed down against the CPU tightly. It can move, and I have a zalman as well, and it could rotate a slight amount to the left and right, but it was firmly fastened against the IHS of the CPU, so its not a problem. Are your temps nice and low?
If you DL one of the free tools, like HWMonitor, you can easily watch the temps, and you'll know right away if its not on correctly! (Or just push firmly down on the top of the cooler, making it press tighter against the CPU and see if the temps go down! If they drop a more than 1 c, then tighten it!)
--Lupi
Profile: Eternal Poster
More Information
Lol, that's not a good sign. The fan should be parallel to the heatsink no matter how much you messed up installation. You should RMA it for a new one, especially if you hear rattling. Also, why are your heatsink fan and case fan drawing air in opposite directions? Aim them in the same direction. It may add to the noise, but it's better. :p
Q6600@3.6ghz, GA-EX38-DS4 X38 chipset motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB 7200rpm 32mb cache hdd, 850watt 12v rails=4x20amp powersupply
Master-de-bater
More Information
Well, it's possible to twist a TRUE around a little, so why not the Zalman?
Anyways, dagger is right about the cooler facing the wrong way. It's better if you face it the other way so the back fan will help the cooler, creating a push-pull effect. This can lower your temps a bit.
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Add a reply
Google Ads
