Tom's Hardware Forums » Overclocking » AMD » OC 6400BE problems
OC 6400BE problems
Add a reply
 Word :   Username :
Bottom
Author
 Thread : OC 6400BE problems
Profile: member
More Information
ok, i am able to OC my cpu up to 3.5ghz. i can do this a few ways:
Setting #1 - 14.5X with 241mhz fsb. memory 5-5-5-12 @ 2.1v
Setting #2 - 15X with @233mhz fsb. memory also 5-5-5-12@2.1v
now windows post fine without a problem. I play a bit of cod4 for 20-30min without a problem. CPU runs @ 55-58C at full load. Now I try to run 3dmark06 and both settings will crash @ the first cpu test. I cant figure this out. My Vcore is getting a health 1.48V. Any suggestions? I have a Coolermaster 212 with 2 fans and its rank top 5 air cooler. Should I be running different benchmarks instead of 3dmark06? ahh help.
Related Pr oduct
You tell me what I do.
Profile: Faithful Poster
More Information
that means something is there is unstable.have you adjust any other voltages?
Profile: member
More Information
not many amd users here?
X2 6400+ BE | DFI LP 790FX-M2RS | Crucial Ballistix 2x1gb ddr2 800 | Primary: Corsair VX 550w + Seconardy: Ultra 325w 5.25"| Coolermaster 212 2x120 fans | Visiontek HD 3870x2 |
More Information
well AMD have flop for the past year or two after the Core 2 series have launched.so i guess many people already switch to Intel for its great performance/watt and high and easy overclockability of its CPU.
back about 2 years ago i was about to get a AMD system as its so much powerful and efficient then the Netburst architechure of the Pentium's.so i praise about AMD before but now FAILED HARD!!!
last advice if you are looking to upgrade again or a fresh build please build a Intel based system as there many support from manufacture to forums like here.
Anyway good luck.
Profile: old hand
More Information
I'm an AMD user still, though my OCs have never been anywhere near that good.  Does it only crash in 3DMark?  If so you could just ignore it.  Does it restart or just crash?  Try some testing software like prime95 and memtest to see if it crashes then.
Gaming: FX-60 @ 2.81GHz (x14, 1.375, 90nm) > A8N-SLI Deluxe > Asus 4850 - 625/1986 > 2GB Corsair XMS 400MHz
2-3-3-6-1T
HTPC/Light Gaming: X2 5400+ 2.8GHz Brisbane > Gigabyte 780G MATX - 900MHz Core > 2GB Corsair XMS2 800MHz
4-4-4-12-2T
Master-de-bater
Profile: Eternal Poster
More Information
I suppose you brought the HT multiplier down by one?
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Profile: member
More Information
I have a 790fx dfi board and the cmos is quite complicated. The HT is under 1000 in cpuz so i dont think the HT speed is a problem.
It only crashes in 3dmark06. I tried prime and it was fine. I tried superPI and it was fine. 2hr of hardcore cod4 and it was fine as well. I dont know what the problem could be. MY temp reaches 55C MAX. Its usually around 50C at full load as I have good ventilation and cooling.
I am currently at 14.5X multiplier and 240fsb. HT is below 1000. Ram is about 850mhz @ 4-5-4-12 2.1V.
Profile: member
More Information
i just read a thread of the videocard section and some people mentioned that ATI does not like OC cpu on 3dmark06. is this true? Are there another reputable program to stress my cpu?
Master-de-bater
More Information
Not being an ATI owner, I can't really see why ATI cards would fail from cpu OC. Well, unless you run 3dmark for a living, it doesn't really matter does it?
I think Prime95 or Orthos is the best cpu stress test out there. Why do you need a better one? Just run it longer, 24hours or so.
More Information
or maybe the problem is your motherboard.have you got another platform to try it on just in case?
max it out
Profile: newbie
More Information
if u can run PRIME 95 and OCCT than your CPU is stable try its your graphics card thats crashind MARK06 try playing with the card and uninstal 3dMARK and install it again and run it before u play withe your GPU timmings , let me no how u make out ?
Add a reply
Google Ads
