Tom's Hardware > Forum > CPU & Components > CPUs > Low Voltage on CPU Help
Hey guys. I hear that for my dual core E6600 the voltage should be set to 1.34volts or something like that. Mine is currently at bios default of 1.184.
Should I increase it? I haven't noticed any problems with it.
Will I get any increase in performance if I increase voltage?
Could I possibly damage it if I increase to 1.34 volts?
Sponsored Links
Leave it alone.
The voltage will fluctuate especially if you are using SpeedStep which slows down the CPU when it is not being stressed.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
oh ok, makes sense. Thanks
Reply to Spitfire7
- 0 +
run a burn in test use prime 95 for two hours, if it pass without any problem or error, then everything is good
for the last two questions, the answer is no and no
cpu performance is base on the cpu speed, not the voltage
you will not damage the cpu even you put 1.6v.
Reply to bob8701
- 0 +
You want the lowest Vcore you can get without errors. Lower voltage = less heat.
Reply to Zorg
good to know, thanks
Reply to Spitfire7
There are 952 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
