Hi all. Just bought this case:
http://www.plaisio.gr/product.aspx?catalog=20&category=69977695&product=1019333
As you can see you can use 4 fans: two 12cm (top and rear, NOT front) and two 9.2cm (they are side-placed facing the HDDs)
I have a E6600 cpu (stock cooler) and a 8800GT vga.
Can you tell me please which fans should bring air in and which out of the case?
Thank you
Thank you
