Hi, this system was finished yesterday and worked fine. Today I changed the boot sequence in the BIOS from Floppy (which is not installed) to HDD and I also disabled the Mobo Logo at start-up.
After that things started going bad. Have changed the bios settings back to default but it didn't help.
Windows starts up and the little dots are sometimes hesitating as they move across when Windows starts.
Then I get to the point with the message telling me that Windows couldn't start and gives me the option to "Start in normal, safe mode, etc. I have tried all options but nothing helps.
At startup I get 1 beep and only for a split second I see the BSOD! with some writing but it goes so fast it's impossible to see.
At this point I can't get to the BIOS in order to change boot sequence to DVD in order to load from Windows and try to do a repair.
Here are the spec's:
CPU:Intel core2 Quad Q6600 2.4MHz
Mobo: Asus P5K3 /Deluxe WiFi-AP, LGA775
Video: XFX GeForce 8800 GT 512MB GDDR3
HDD: Western Digital Caviar 500 GB
Ram: Corsair 2 GB DDR3
PSU: Thermaltake Toughpower 700W
Does anybody have any problem with this ASUS Mobo and the CPU Q6600?
I appreciate any ideas!!!! Thanks
