I've searched this forum for threads containing the Throttling problem of Dual Core AMD's but didnt find a similar topic , so I'm posting here a problem I have and searching an answer for almost a month
Problem started when I replaced my old Sempron 3000+ with a Dual Core Athlon x2 6000+
What I'm experiencing is a large frame rate drop (from 45 fps to 15 or less than 10 some times) when I'm playing any 3d game on my comp.
I have every latest driver installed (mobo, graphics , cpu ... etc...) but no fix... also tried hotfixes , the amd Dual core optimizer and the amd driver all to no avail...
I found the source of the problems to be Throttling of my processor which I found out using RightMark CPU Clock Utility (RMClock). The Cores go from 3000 Mhz to approx 1500 for a short period of time (approx. 10-15 sec) and then back to normal... The temperature as stated by that program is less than 50oC so it shouldn't be a problem in the 1st place.
Also I disabled AMD's Cool n quiet feature from bios and from windows and also any power management thingy to be sure but still it throttles by itself...
one more thing I tried was downclocking the processor's cores from 3000 to 2400 (mutliplier from 15 to 12) so the same problem happens cutting cores in half ! (from 2400 to 1200 Mhz ! )
It's pretty annoying situation having a brand new cpu and getting these frustrating thing all the time ... If anyone has a piece of advise plz reply asap
Thanks for your time!
COMPUTER SPECS:
CPU : AMD Athlon 64 X2 6000+
RAM: 1,5GB@533
ASUS AM2-TVM (Bios REV 8.02 - Latest one)
Graphics: Nvidia GeForce 8600GTS 256MB
PSU : Premier 500Watt (really cheap one)
OS: Windows XP Pro (x86)
COMPUTER SPECS:
RAM: 1,5GB@533
