Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Artic Cooling Freezer 7 Pro
Is there a better cooler then the Artic Cooling Freezer 7 Pro at that price range for a q6600, seems like its the choice around the 40 dollar mark?
Sponsored Links
The Xigmatek: http://www.newegg.com/Product/Prod [...] 6835233003
Frostytech ranks it as the best cooler, although many people still regards the TRUE the best once lapped properly.
You can hit 3.6GHz on the Q6600 safely using the Xigmatek.
------------------------------ "Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
Here's Frosty's review of the Xigmatek s1283. I'd get it over the ACF7Pro, since it's only about $5 more and cools much better.
http://www.frostytech.com/articlev [...] cleID=2233
------------------------------ PSU Tiers
GPU Power
8800gtx w/e6600 OC'd will run on Antec 380w w/27A on 12v rail, PSU!!
Reply to lunyone
This is all you need to know.
Thermal Resistance 0.16 ℃/W for the XIGMATEK HDT-S1283 120mm Rifle CPU Cooler. $36.99 shipped lifetime warranty
Thermal Resistance 0.17°C/Watt for the ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler $31.99 shipped six year warranty
$5 dollars for about 1C degree difference in cooling ability at stock CPU speed.
Shop around and you can find the 7 Pro cheaper.
The Xigmatek is a bit harder to install.
Reply to bobbknight
it depend on your VID on your processor.my high VID 1.3000V Q6600 cant overclock anything over 3ghz with the Artic Cooling Freezer 7 Pro(lapped).bios 1.35v load 69C.but i have seem some overclock to 3.2 and 3.3ghz with low VID
but if 3ghz is your aim go for it!
Reply to iluvgillgill
If you have good back case fan the AC pro 7 is very good.
Don't know about Xigmatek, but mine AC keeps my e2160 @ 3.0 Vcore 1.36 in idle at 34oC load 45oC(58oC cores), and without back fan it goes way up to 63oC and 70oC on cores.
Reply to Eric Tardes
back fan and front fan is a must as its needed for the air flow inside the case.but the OP and me is OCing a quad core.so heat output will be much more higher if not twice!lol
There are 577 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
