Hello,
Some of you may know that I recently built a computer. Everything has gone fine, up until this point. I used my a neighbors LCD for first boot up, but I can't keep using it. I am trying to use an old 15'' or so dell monitor. The problem with that is that the cable is a 15-pin male(has the little pins sticking out). I need it to fit into my new computer's 8 pin female slot(little holes that accept the pins). Does anyone know of an adapter of some kind that will allow me to use this monitor as a temporary solution, or am I screwed until I can get a new monitor?
Again, I really don't know what the adapter would be called or even if there is one...so I can't really do a search on it.
Thank you,
-Adam
Thank you,
-Adam
