Tom's Hardware Forums » Overclocking » CPUs » HELP!!!... Stability Phenoms System OC'd
Add a reply
 Word :   Username :
Bottom
Author
 Thread : HELP!!!... Stability Phenoms System OC'd
Profile: journeyman
More Information
Can you helped me with build a system w/ Phenom system base and an ATI 3870 on graphic. And i'm want to "play a scoring mark" with the Phenom. I want a stability on the system when comes to OCed, i'm a little bit confused here. This is my first time build an AMD system and OCed, usually "play" with Intel. First of all, thanks for the choice.
Related Pr oduct
Profile: journeyman
More Information
Oh i forgot, i have budget around $ 1,100
...I like you
Profile: addict
More Information
OC'd and Phenom don't really go together :(
"He is no fool who gives what he cannot keep to gain what he cannot lose" -- Jim Elliott
Profile: journeyman
More Information
you mean, phenom coudn't OC'd?
Profile: stranger
More Information
what he meant to say was this
http://www.xtremesystems.org/forum [...] p?t=183025
Tony from OCZ OC'd his phenom to 3.5ghz
Die to spawn in another 10 seconds
Profile: newbie
More Information
Nice overclock...for a Phenom :p But so what. I'm able to overclock my X3350 to 3.7Ghz with just using "Auto" settings in my BIOS while using over 100 watts less power and maintain much cooler temps. Oh, and I don't need watercooling to overclock it that high either (Notice how "Tony, the Jedi Master" is using a liquid cooled system). I have a 100% air-cooled system. I'm using a Thermaltake V1 copper heat sink. My system is rock stable in both 3DMark06 and Prime95 with my X3350 @ 3.7Ghz w/1.34V :sol:
Seriously, no AMD bashing. AMD has finally introduced a product worth buying...albeit $245 for this "very late to the game" processor is a bit high. They should be selling it for about $180.
Regardless of direct performance comparisons (Current Intel CPUs completely dominate anything AMD has...for now), I love competition...Intel VS AMD...the consumer always wins!
Intel Xeon X3350 @ 3.8Ghz (Thermaltake V1 Copper Heat Sink)
EVGA 780i SLI MCP motherboard - 4GB Super Talent DDR2800
2 x 8800GTS 512MB cards in SLI @ SSC speeds (700/1750/2000)
Thermaltake Toughpower 850 PSU - Antec 900 PC Case (Rev 1.1)
Profile: journeyman
More Information
Uuhhhh... That's really nice. But, how the system stability? I'm a bit worried, coz i really had a bad exeprience. When i'm OCed my old P4 2,4 Ghz to 3,8 Ghz, the board got blown up. Pretty stupid i think.
Profile: newbie
More Information
Not stupid, because I know what I'm doing. I don't want to be rude. But, that's your problem. I have no issues with my set-up whatsoever. I do know how to manually overclock and adjust voltages. Is it the safer way to go versus using the "Auto" settings? Sure (especially for beginners who don't know what to look for). In my particular situation, it doesn't matter either way. But for some with different set-ups, it probably won't work correctly.
Besides, why the heck are you bringing up an example like that??? P4 2.4Ghz? Motherboards back then weren't designed for the type of overclocking that is done today. No multi-phase capable MOSFETS, no solid capacitors, ...nuff said! Please use a recent example. I've never heard of anyone blowing up there motherboard using "Auto" settings. I've seen a few fry their E8400s though by MANUALLY setting their voltages past 1.5V...
Message quoted 1 times
Message edited by Ninjawitha gun on 04-23-2008 at 02:48:39 PM
Master-de-bater
Profile: Eternal Poster
More Information
Probably because all the hardcore OCers don't use auto settings? And people who does use auto tends to be moderate OCers, so there's very little issues with that.
"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Profile: journeyman
More Information
yeah, i guess its old stories back with my P4. by the way i use manual OCed with intel D865PERL. But i'm satisfied and brought another P4 3.06 Ghz standard clock and still running until now. But, i want try out the AMD latest Processor for my investment. Hopefully last for 2 years before crazy game resource eater published.
Master-de-bater
More Information
The Phenom, AMD's latest CPU, is rather a poor OCer. However they do offer a great bang for the buck when OCing isn't considered.
Add a reply
Google Ads
