I am building a computer at the moment and ran into a problem.
My motherboard has a 24-pin pwr1 slot and the plug from the power supply is only a 20-pin.
Also my motherboard has a 8-pin pwr2 slot and all I see from the power supply is a 4-pin and a 6-pin plug.
Can I just stick those in anyway or do I need to go get a new power supply?
I have had cases where the 20pin into the mobo is sufficient for the 24pin mobo. However, in most cases it just wont work. You need another PSU dude. The 8pin on your mainboard though can take the 4 pin off the PSU and run fine
Hmmm, what did you buy? Hopefully it was from Tier-3 or better from the list at http://www.tomswiki.com/page/Tiere [...] gs?t=anon. If not, perhaps the sales guy is hoping you do indeed have some experience with fire so you'll buy more parts from him.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Burn baby burn burn!!!
------------------------------"This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Yeah, it's good stuff. It's not on that tiered list but it should be in tier 2 or 3. That is, it's almost as good as the GameXStream which is in tier 2.
