Tom's Hardware > Forum > Homebuilt Systems > New System Build > Noob building first custom...need mobo advice
Forum Homebuilt Systems : New System Build - Noob building first custom...need mobo advice
Ok so i'm getting my first custom built comp and i'm having trouble deciding which mobo would be the best for me...i'm buying a barebones system, so i only have a few choices on what to get...i've already purchased most of the components that i'll be installing...here is what i've bought so far:
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
SAMSUNG Black 20X DVD+R 8X DVD+RW 16X DVD+R DL 20X DVD-R
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
EVGA 512-P3-N802-A1 GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card
Now here are the board choices i have... i'd like a board for gaming, one that i can use the above components in...i'm not really interested in ocing or anything like that...but i'd like a board that will last me a good 3-4years...also i'm planning on getting the Q6600 as my processor...anyway here are my choices:
Gigabyte GA-P35-DS3L P35, 1333FSB, PCI Express, DDR2, Sound, 1Gb LAN
ASUS P5K SE P35, 1333FSB, PCI Express, DDR2, Sound, 1Gb LAN
ASUS P5N-E SLI nForce 650i, 1333FSB, SLI PCI Express, Sound,1GB LAN, iEEE
ASUS P5B-E P965, 1333FSB, PCI Express, DDR2, Sound, 1Gb LAN, iEEE, Quad
ASUS P5N32-E SLI Plus nForce 650i, 1333FSB, SLI PCI Ex, Sound,1GB LAN, iEEE
ASUS P5N32-E SLI nForce 680i, 1333FSB, SLI PCI Ex, Sound,1GB LAN, iEEE
eVGA 122-CK-NF68-T1 nForce 680i, 1333FSB, SLI PCI Express,1Gb iEEE
so any suggestions on what board would be the best?...thanks...
Sponsored Links
I used this on many builds but be careful when buying a HSF, as the north bridge is too close to the CPU. Apart from this the motherboard is vary stable. I just built one this friday and OCed a E2180 to 2.7Ghz stable out the box. I can go to 3Ghz+ on this board, but needs better cooling.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
- 0 +
I am finishing an install on a new PC for my cousin as we speak, using the Gigabyte! I recomend it.I have an ASUS Striker in my own PC, nightmare to get running properly, the Gigabyte was a treat. I know where my money will be going next time.
Reply to ooral
im running an asus striker extreme and i like it but it would have problems with the memory that u have selected
Message edited by dwthor02 on 12-02-2007 at 02:27:28 AM
------------------------------ Intel Core 2 Extreme QX9650, Striker Extreme, 2x 150 gig raptors, 4x 500 gig wd, 2x 8800 ultras,creative labs audio X-FI Xtreme Gamer, 4 gigs memory corsair dominator ultra x connect 1000watt psu, amd x2 6400 2 gig xms2 @ 800mhz, 2 8800 gtx oc2 by bfg 2
Reply to dwthor02
the only thing is the gigabyte doesn't support sli...i'm only buying one card as of now, but i like the option of being able to add another if i choose too...
Reply to lunercrab
There are 1306 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
