No errors when running the small FFTS torture test.
And how long did you run that test?
The blend tests what ever memory is available. So that would be an indication perhaps memory problems are there. Are you setting the memory voltage to its spec's?
I would agree with running memtest x86. The tests (including Prime95) should be done for at least 6 hours.
Edit:
Orthos would be easier to run, wouldn't have to start separate tests.
Message edited by Grimmy on 12-10-2007 at 04:54:21 PM
