Tom's Hardware > Forum > Storage > Hard Disks > Hard drive problem
Hard drive problem
Forum Storage : Hard Disks - Hard drive problem
Hi
I have a hard drive that dosent want to work with windows anymore.
When i boot my computer with windows it freezes after the loading screen and restarts after about 5-10 min.
But when i boot with ubuntu from a live CD it works. And i can see all the files.
It's a Western Digital Caviar 500GB about 1 year old.
Sponsored Links
Down-load and run the HD manufacturers drive test tool (or Ultimate Boot CD) and see what it says.
Reply to MrLinux
I would copy the files off, before you do any testing or booting to the drive, or you will loose them.
The WD6400AAKS is fast and relatively cheap.
I would buy it and load windows with only that drive installed. Then I would put the old drive in as a second drive and copy off the needed files.
If you can't get the files off you could use SpinRite hard drive data recovery software.
Reply to Zorg
But it's the second drive, i already have windows on another drive. I dont care about the files i just want it to work. I have tried it in another computer. And when it's connected the computer freezes after the boot screen. Just like in mine.
Reply to Tensu
Then the drive is shot, RMA it or throw it away.
What PSU are you using? A junk PSU can eat drives.
Turn SMART on in the BIOS. You can also download SpeedFan and click on the SMART tab.
Also there are drive tools on Western Digital's site that will test the drive.
Message edited by Zorg on 09-20-2008 at 07:50:52 PM
Reply to Zorg
I fixed it by myself. I used a HDD eraser that came with Ultimate Boot CD.
So thanks for the help MrLinux
Reply to Tensu
Oh, you were talking about booting to windows. I should have read more closely. It's not likely that a drive will boot in a different computer anyway.
A format should have fixed that. Zero writing a drive is a good idea anyway, IMO.
Message edited by Zorg on 09-20-2008 at 09:55:04 PM
Reply to Zorg
There are 1230 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
