Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » is this a good Water cooler?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : is this a good Water cooler?
Profile: member
I want somthing that would fit in a drive bay like this one. I'm wondering if this would do the job when I get a Phenom X4 9850. http://www.newegg.com/Product/Prod [...] 6835106108 mainly I want to cool my CPU better than my Tuniq Tower and this is my case. http://www.newegg.com/Product/Prod [...] 6811144010
http://valid.x86-secret.com/cache/banner/360593.png
Related Pr oduct
Profile: member
More Information
No to the W/Cer. No to the case.
Profile: old hand
More Information
heh, the most recent newegg review said he had to trim the computer case to get it to fit and still gave it a perfect rating. It looks like a terrible design.
Exchange Engineer - Am I working to live, or am I living to work?
Profile: old hand
More Information
If you have the tower already, the only way to bring down the CPU temp is to move more air across the cooler and through the case. Also lowering the ambient air temp going into the computer will help.
Profile: stranger
More Information
Hi regarding the water cooler, the main problem with watercooling like that thermaltake one is airflow. It's important to get the air where the radiator is as cool as possible, and looking at the case your interested in i don't think it's a good idea to have an internal radiator in such a small area.
if your thinking about watercooling still you may want to have a look at some external coolers, Koolance and Asetek have decent models going around http://www.newegg.com/Product/Prod [...] 6835127006 is one i found on newegg, but you may also want to check www.frozencpu.com for some other coolers
If you want better cooling and don't mind punching a hole or 2 in your case swiftech make great watercooling kits and they are really easy to install (i've set 3 systems with them already easy as)
and if your paranoid of getting water on your hardware you can invest in some Fluid XP since it's none conductive
Anyways i hope this helps
Oogabooga
Profile: member
well my problem is this my case is a mid tower and a dual radiator setup would block my 8800 ultra I was thinking of adding a radiator if I get the tt one. I think 1 120mm radiator with a fan blowing out http://www.newegg.com/Product/Prod [...] 6835127087 that is where the water will go first to cool down then from there it'll go to the tt radiator which I think I may just take the fan off just so the hot air won't be there but sence it's going to go to the one radiator I plan on putting in the back first I may just keep it sence the watter will be some what more cooler. I'm also going to get the Swiftech CPU block sence I don't like the one tt has. I'll just need to get the nozzel for the radiator.
Add a reply
Google Ads
