Tom's Hardware Forums » Overclocking » General Discussions » Help me push my Q9300 past 2800 MHz
Word :   Username :
Bottom
Author
 Thread : Help me push my Q9300 past 2800 MHz
Profile: stranger
More Information
New to overclocking. Seem to be stuck at 2.8GHz - system is running stable at this point, but if I raise the clock beyond this, it will freeze after a while or not post. Tried messing with the voltages but can't get it to run higher - I am sure I am not applying the right combination of volts, timings, etc. The only changes I have made so far are to increase clock to 400 MHz, set 1:1 ratio (FSB:DRAM), increase DDR2 voltage to 1.9 V from default 1.8V. System is staying cool - CPU idles at 12 C, load at 20C.
Would like to get my rig to 3 - 3.2Ghz which should within the realm of possibility for this board and CPU on air. Please help with suggestions.
Q9300 @ 2.8 GHz (stock volt 1.125V), Abit IP35 Pro (FSB 400 Mhz), Geil DDR2 800 2 x 2GB memory (1:1 DDR2 800, 1.9 V), ZeroTherm BTF90, Antec NeoPower 650, EVGA GeForce 8800GTS 320MB, Lian Li PC-60BPLUSII (2 x 80 mm, 2 x 120 mm case fans).
Related Product
Noob? Currently on Sabbatical!
Profile: Honorary Poster
More Information
Try setting the Ram on auto wile you stabilize the CPU? And if you havent changed anything, that means its all on auto? I am not sure about the q9xxx series processor itself, but you do need to do all the basic stuff.
North bridge to 1.45 or so, disable all the spread spectrum junk you can find! Disable the processor options like c1e, vanderpool, disable bit, etc. (Not CPU internal cache!) And then disable whatever you are not using.
(You kinda wanna have everything on stockish while getting the CPU to OC. That way you know what to blame any problems on.) I cant give you VCore requirements because I havent played around with the newer chips, but you'll prolly need to add some, if you kept it on stock.
--Lupi
Profile: Ancient Poster
More Information
You cant increase the Clock to 400 Mhz AND set the ram to 1:1 ratio while running @2.8Ghz. That would have left you at 2.8Ghz.
You may want to increase the CPU to 1.3V which is safe and well as increase the NB as mentioned above.
If its good in theory but not in practice,
its not good theory.
Profile: enthusiast
More Information
Make sure to lock the PCIe bus to 100MHz.
Profile: stranger
More Information
- PCIe bus is locked at 100 MHz
- RAM is set on auto (By SPD) - and has switched automatically from 4-4-4 timings to 5-5-5 when I moved the clock from 333 MHz to 400 MHz.
- zenmaster, sorry, I did not understand the first line of your comment, is that a typo there?
Profile: stranger
More Information
OK, got it to 2940 MHz stable (420 FSB) - pushed VCore to 1.135V and RAM to 2.0 V, timings on auto, Prime95 went 4 hours with no issues. Then tried 444 MHz FSB with no other changes and Prime95/system froze after 1.5 hours. Any suggestions?
Profile: stranger
More Information
Just out of curiosity, why are you trying to overclock it?
Just curious as to what applications you are looking for help with here, as it's plenty fast enough for most things now.
Profile: nimble knuckle
More Information
You do realize that this is a hardware enthusiast forum right? we dont need a reason to OC!
macgirlfriend:
"Hey I don't get you people, the people on insanely mac were so much nicer"
Profile: journeyman
More Information
http://processorfinder.intel.com/D [...] Spec=SLAWE
Raise the voltage, 1.135v is very conservative for this chip. Remember also that you get vdroop on most motherbaords, so if you have it set to 1.135v in the bios it may only be getting just over 1v. Get up to a true 1.2v to the processor and you should make your goal, just watch the temps.
More Information
He is running a $285.00 processor at the speed of a $609.00 processor for free. Actually faster than the $609.00 processor at stock.
Message quoted 1 times
Message edited by evongugg on 04-29-2008 at 06:03:46 PM
Scruze my English!
Can't. . . stop. . . upgrading
Profile: enthusiast
More Information
Do you really mean 1.135 or 1.35? If the former, then you have to increase it more. I'm surprised it runs at that speed on that voltage. If the latter, you still might have to bump it up, but it will get hot fast. Either way, RAM voltage should probably be set to 2.0 or 2.1 just to be sure.
They call me crazy for yelling, alone in my room, at the computer screen. They just don't understand the game.
Profile: stranger
More Information
Ya got it!!! Why leave money on the table if it can be had, without hurting anyone???? For apps, I do quite some amount of video editing and encoding and OCing definitely helps shave minutes off of long encodes.
The chip is running at 1.135V not 1.35, I will bump it up some more. Should I increase NB and ICH at this time from default? Also, can I enable SpeedStep so I can drop power consumption when idle? Thanks all.
More Information
Try reading one of the overclocking guides before asking someone to hold your hand.
kad
Profile: addict
More Information
Now disable SpeedStep till you finish your OC and get it stable
Then try to enable and see the result
If it became unstable it means you have to disable
Sorry don't know much about this processor but what is the default FSB and Multiplier??
Google Ads
News
Vendors form collaborative to push AJAX
Published on February 01, 2006
The market for AJAX (Asynchronous JavaScript and XML), a technique for developing interactive Web applications, is heating up with the announcement today that several vendors, including IBM, BEA, Borland, Novell, Oracle and Red Hat, have formed a collaborative to help push AJAX in the open-source community. Read more
AMD sneaks out Athlon 64 2800+
Published on March 30, 2004
AMD yesterday quietly added an Athlon 64 2800+ processor to its product list. Read more
ATI to push sales of HDTV Wonder card
Published on August 19, 2004
ATI Technologies is gearing up to push sales of its HDTV Wonder TV tuner card, according to sources at Taiwan graphics card makers. Read more
AMD introduces low-power 64-bit processors
Published on May 06, 2004
AMD today added two new low-power mobile processor for the thin and light notebook segment. The mobile Athlon 64 2800+ and 2700+ sharply decrease the power consumption of other mobile Athlon 64 processors. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
