Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Two power supplies powering 1 system?
Forum CPU & Components : Power Supplies, Cases & Mods Two power supplies powering 1 system?
Heres my situation:
I thought my video card was defective, so I requested an RMA to support and they told me to check my power supply to see if it's strong enough. They recommended me to disconnect the cd drives and case fans. I attempted what they suggested; my problem was solved; yet now I need a new power supply.
Till now I realized I have an extra PSU laying around. it is 450W.
I wonder, if I can use my current PSU 600W to power everything else, and let the 450W power the cd + dvd drives and case fans. Is this possible? Will this raise the electric bill? Is it dangerous?
Message quoted 1 times
Message edited by shall1990 on 12-12-2007 at 11:33:30 PM
Reply to shall1990
It is possible. You can get small add on power supplies which power video cards, I have seen them at some retailers. You have to figure out where you are going to put the second power supply.
It would use more power than just a 600 W power supply but I dont think it would use substantially more power than using a 750W or whatever you would need. As to specific dangers - I wouldnt think there would be any but some else should probably comment on that.
------------------------------ AMD 64 4600+ --> Soon to be Q9450
2 GB Kingston DDR 3200 --> Soon to be 4GB OCZ platinum DDR2-6400
x1950 PRO --> Soon to be 8800 GT
Stupid X-fi --> Sigh, no change
Reply to dashelj
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
- 0 +
shall1990 wrote :
Heres my situation:
What in the hell are you running that a 600 W PSU won't support? (I could do mild welding with 600W!) Or is it a 600W rosewill....
Anyway your plan to power the drives and fans with the 450W psu WILL work, but it will be a messy solution. I envision a PSU lying on the ground, witn molex extender cables running through a butchered hole in the case....
Reply to croc
Quote :
Amen to that! What's in there? Quadcore? EE- or D-series P4 CPU? SLI/CF VGA config? Or just one 2900? :lol: (two 2900XT's in CrossFire could do it, you'd need half the National Grid for that! :sweat: :lol: )
Either get a bigger PSU, or get an add-on module as described above. Use the DIY fix you outlined only temporarily if you're desperate. But if you don't have one of the above it does suggest something is wrong... in which case try the 450W, it should be capable of powering a system on its lonesome if you don't have some crazy OCing or a dual-card setup going!
Reply to Solitaire
Heads up, my system takes 330 watts from the wall and under 300(bout 280) on the DC side.
Pr
Load test isime95 and 3dmarks 2006...and winamp for good measure....
Case: Antec 900
PSU: OCZ 700watt
Board: P35 DS3R
CPU: Q6600 @ 3.00
CPU cooling : Zalman 9500 @ 500-2200 rpms(PWM)
Memory: 2x 1024MB ,2X 512MB @ 4,4,4,10
Video: 8800GTX 600(core) 1400(shader) 900 x2(memory)
Storage:
2x WDC 250gig (Raid0)
2x Seagate 320gig(Storage)
2x Seagate 500gig(Storage)
1x 500gig Seagate (Backup-external) - Not included as its getting power elsewhere
Optical drive: Samsung SH-W162[Dying as you read this]
KB/Mouse: Logitech Access 600 :), G9 Mouse
TV card: PVR 250
Sound: Creative SB Audigy 2zs
Screen: Samsung 950b (LCD) - not included 30-35 watts
Speakers: Altec Lansing Select 641 - Not counted on the 330 as they vary allot with volume
So..... as said above, what the hell needs 600+
Message edited by nukemaster on 12-13-2007 at 02:34:19 AM
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/yfmxdc9 - Part Guide? http://tinyurl.com/5zk6me - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yjldsrw - No Boot?
Reply to nukemaster
I experimented once and spliced 2 250w power supplies together, and it worked. all of my drives and HDDs were ran off of one, and the mobo was hooked into both. the comp looked like a freak with a power supply welded to the outside of the case with wires going everywhere.
------------------------------ *This signature is for sale. Will accept cash, check, or Visa*
Reply to dmacfour
- 0 +
I hate users like op. Just looking for the answer and not contributing at all. Others are just curious, how much pain is it to just tell us what setup you are running. SUCH a LEECH :fou:
------------------------------ Case: Antec 900 <<||>> PSU: ThermalTake ToughPower Modular 850W, <<||>> Memory: 4x1GB Crucual Ballistix 6400 <<||>> Q6600 stock running at ambient + 1C <<||>> Mobo: GigaByte p35 GA-p35DS3P <<||>> Dual Dvd Writer <<||>> 2 x 400G seagate sata drives <<||>>
Reply to nuklep
Isnt that part point of a forum? ask a question get an answer.
I dont see you complaining when someone asks whats dual lan for or some other legitimate question. Why do we need to know what his rig is if all the OP asks is how to run 2 PSU's at once on the same machine? You give an answer and move on...
Reply to chookman
You've got to see this
http://www.tomshardware.com/forum/ [...] ion-8800gt
Reply to delluser1
- 0 +
sure "get your answer and move on" works, but how does that make the "online community" a real community? It lacks that feeling. Thats just my idea.
Reply to nuklep
I believe theres a community here , you only have to check out some of the flame war threads or the people that wear there heart on there sleeves. There alot of respect for the long time posters and plenty of conversation to boot. However, I believe sometimes a simple question just needs a simple answer.
Reply to chookman
- 0 +
And what have you contributed, stranger, in your 17 posts? I hate strangers that pop in here and immediately start criticising... So either contribute, or just watch and learn. Asking questions, imo, is often a valuable contribution.
Reply to croc
- 0 +
I've got to agree with croc's first post in this thread. What are you running that a 600W PSU can't handle? The best suggestion you may get is to:
a. refer to the PSU calculator at http://www.extreme.outervision.com [...] orlite.jsp to determine your load, then
b. Choose a big enough unit from tier-3 or better from the list at http://www.tomswiki.com/page/Tiere [...] gs?t=anon.
If the PSU calculator suggests that you need, say, 430W, then you know that either your "600"W PSU is a Rosewill or other piece of dried poo, or you have other problems in your build that are adding unaccounted-for load, which another PSU won't fix.
------------------------------ Save your money. Step outside the incessant churn.
Reply to jtt283
- 0 +
Falling on oh so convenient Ad Hominem Tu Quoque? As far as watching and learning, do you think my post count will tell you how long i've been watching? or will even my join date say anything? I've been watching longer than you think. I try to add where I can. When I don't have a response I don't say anything. maybe that explains why I have 17 posts. I don't make "I agree" posts to swell my post count. Because post count does not tell the whole story. You miss my point. I am just asking for a better community feeling. But I guess if honorary posters like you here stomp on 17 count posters, it will never happen. And if you think I am stomping on a 2 count poster, remember I am just asking him to post more (not asking him to shutup)
Reply to nuklep
- 0 +
I hear you nuke, my DVD+-RW DL is dying and fails to eject properly ~90% of the time.
[highjack over]
I am also confused what would constitute using such a setup of dual PSUs (especially because it's not being used for parity).
------------------------------ Lian-Li PC-7B | XClio Greatpower 550W | P4 3.2 Prescott SL7E5 | Scythe Ninja
2GB DDR400 Corsair VS (4*512) | eVGA nVidia GF 7600GS AGP vmod 1.46/1.91 OCd 759/907
WD 160GB & 640GB SATA
WinXP MCE 2004
Reply to KyleSTL
- 0 +
You guys have to keep in mind that its the amps on the 12V rail/s and the effiency of the power supply that matters, not simply the wattage. If I were you, I would sell both my power supplies and buy a pc power and cooling silencer 610 watt supply.
Message edited by dodian on 12-13-2007 at 11:11:00 PM
Reply to dodian
it would actually be easy to do what the OP wants, but why?? he obviously (to me) has a failing ps if its rated at 600 and cant run his system.
Reply to michiganteddybear
- 0 +
"I hate users like op. Just looking for the answer and not contributing at all. Others are just curious, how much pain is it to just tell us what setup you are running. SUCH a LEECH"
Looks more like a flame to me, rather than a request to the OP for more information....
Reply to croc
If your PS has multiple 12V rails, you might be near the limit on one, in which case you can try to rebalance the load by switching power connectors around.
Reply to coldneutron
- 0 +
point taken. 4 other posters had requested more info and it was just frustrating to see op ignore all those requests
Reply to nuklep
- 0 +
I was also requesting more information, but if the OP doesn't want to respond, oh well. Maybe some day we'll find out what the OP did, maybe not. Either way, most of the community did their best to try to help, with what limited information was available.
Reply to croc
- 0 +
The whole flame war is kind of funny. I see all kinds of threads started with insufficient information to even consider giving any assistance. Does the OP think we are mind readers? Many posters did indicate that his 600w PSU was probably a POS, and it probably is, but we don't have a definitive answer. The OP is ready to add his 450w PSU to the system which is, more than likely, the most foolish thing to do in his circumstance.
@OP: Try posting your specs, so that you can get informed advice. If you have a junk 600W PSU, then adding a 450W PSU to mask this will probably result in the destruction of your whole system.
Or, just add the additional PSU and take your chances. Be sure to post back when it fries, and let us know if there were any pretty flames.
Reply to Zorg
- 0 +
Thank you, Zorg.
Red flames, and the blue magic smoke, "ooh what pretty colors!"
Reply to jtt283
- 0 +
I feel compelled to address niklep's post and subsequent defense.
The only one that gets screwed by the OP not posting his specs is the OP, because he is the one that will get poor advice. It appears that you were pissed off because you wanted to know his specs for curiosity sake. And for that you went on a rant and flamed the OP. When you were called on the fact that you were acting like a ten year old child, you back peddled. It doesn't matter how many posts you have. You embarrassed yourself, I suggest you take a chill pill.
Reply to Zorg
jtt283 wrote :
Thank you, Zorg.
Woahhh blue smoke? im there...is that like a cool mod?
EDIT: jtt283 you made a booboo in your rig HD3780?
Message edited by chookman on 12-14-2007 at 12:30:00 AM
Reply to chookman
- 0 +
Aw gee, no wonder I couldn't get the fan to work right, I loaded drivers for the HD3870! :bounce: :pt1cable:
(Thanks, I fixed it)
Reply to jtt283
My power supply is an 600w Ultra XFinity There are two 12v rails. +12V1 is 18A, +12V2 is 20A.
sorry
Gigabyte P35 DS3L
Intel core 2 duo E6750
8800GTS 320mb
Sound Blaster Audigy 4
According to the PNY technitian,
"But one thing concerns us, this card requieres 26Amps onthe 12 volt rail. You fall short on your power supply for this.
Try using just the Harddrive which Windows boots of, and disconect every other device, DVD CD Fans etc.
Just power the cpu fan, video card and main hardrive and test again. If it works this way, then the issue is power only."
So I tried what he requested and it worked, oh, my problem was changing a game's settings like resolution, the game would lock up.
Reply to shall1990
- 0 +
This is from the specs of the from PNY's website.
Quote :
A minimum 400W system power supply (with 12V current rating of 26A)
That is 26A on the combined 12V rails. You can't just add the rails together to determine this, but I am certain that the specs on that PSU is more than 26A on the combined rails.
The problem is that the Ultra XFinity is a tier 4 PSU. This means that it is one tier from the bottom of the list.
See Official XS Tiered PSU Manufacturer Brand Listing Phase III.
I suspect that there is something wrong with it as well, because even though it is a low quality PSU, it should still be able to power your system.
Rather than try to run PSU's in tandem, I would opt for a new one. This of course assumes that you have the cash.
What is the Brand and model of the 450W PSU that you have? And do you have the cash for a good High quality PSU?
Reply to Zorg
sorry
Gigabyte P35 DS3L
8800GTS 320mb
For the record
http://www.ultraproducts.com/produ [...] ductID=388
This shows 420w on combined 12v rails... = 35amps. I think the PNY tech has no idea.
In saying that though Zorg is right the is more than likely something wrong with the PSU. If you can buy a new quality one Corsair 520HX comes to mind.
Reply to chookman
It's a Codegen 450W, I don't even see that brand on that site's list.
+12V is 16A
With my current PSU, would switching up the molex plugs work?
Reply to shall1990
I'm also sure I will be able to sell both of my PSU's to buy a good one through the local listings.
Reply to shall1990
- 0 +
I looked up the Codegen it is clearly junk and also unusable. How much cash do you have to put toward a good PSU?
Reply to Zorg
I may have a little over 100 for a new PSU after Christmas considering I still have last minute Christmas shopping to do.
Severely disappointed, my local computer store recommended this power supply for my system. Wish I came here first.
Currently it isn't the biggest deal, but I mod a game called bf1942 which requires opening and closing the game, this will practically lock up the system about the 7th time doing so.
I"m also afraid to buy online, I bought a PSU online from zipzoomfly and it was DOA, And I recieved 0 customer support. impossible to get a refund or a replacement!
Message edited by shall1990 on 12-14-2007 at 04:48:34 AM
Reply to shall1990
+12V is 16A
Thats 1 amp more then the 250watt i have in the closet.... In its defense it runs a E6600 and low end video just fine... :)
I have seen too many Ultra PSU's mess up. just replace it...I suggest a good 500-600 watt only to get max efficiency out of it. Your system should draw 250-300 max.....
Corsair has a nice picture of the efficiency of PSU's, not quite accurate but gives you the right idea of why a half loaded psu saves you power :)
http://img96.imageshack.us/img96/7291/clipboard08zi7.gif
A test done on SPCR
http://img59.imageshack.us/img59/5453/clipboard05ol3.gif
the 250-300watt zone is perfect on this psu.....well near perfect for a machine with your configuration....you may even be under 250....if your not over clocking and depending on other hardware like HDD's....but from 200-300 this thing is perfect for your system...
With you budget....hmmm lets see
Seasonic S12II 430W - 30 Amps
Antec Earthwatts 430W - 30 Amps on the 12 volt rail(s) - on sale often
Corsair CMPSU-450VX - 33 Amps on the 12 volt rail
OCZ StealthXStream OCZ500SXS - They are unclear.... 30+ they have all the voltages rail combine.....so i assume the less 5 and 3.3 you use the more 12 you get....up to a point....
Zippy HG2-6400P - 12V @ 30 Amps on the 12 volt rail
the top 3 are all Seasonics.... Either way there are lots of PSU's around just make sure you get enough on the 12 volts rail,
I am more brave with my own stuff....
E6600 + X1900XT(similar power to your system) on a 380 watt antec with 18 amps :)
Message edited by nukemaster on 12-14-2007 at 05:28:01 AM
Reply to nukemaster
- 0 +
Yup, they screwed you. In their defense, they probably didn't know any better.
Below is a short list of my preferences for your budget in order of highest to lowest. These are all single rail solid PSUs, with plenty of 12V current. There are plenty of other good PSUs out there so this list is not exhaustive by any means. I'm sure others will post their preferences. If you choose a different PSU be sure to check the listing linked above and additionally see if it is reviewed on jonnyguru. Here is a link to the search page on his website. Newegg is very good about DOA parts, that's why they charge a little more sometimes.
PC Power & Cooling Silencer 610 12V @ 49A
CORSAIR CMPSU-550VX 12V @ 41A
CORSAIR CMPSU-520HX 12V @ 40A
CORSAIR CMPSU-450VX 12V @ 33A
Message edited by Zorg on 12-14-2007 at 05:32:31 AM
Reply to Zorg
Your power supply has 2 PCIE connectors, each on a separate 12V rail. Your video card only has 1 PCIE power connector. Try switching the PCIE power connector on the video card to the other one. One of the 2 rails also powers the cpu. If this is the same rail as the connector on the video card it could draw near the max. power of the rail and cause the problem.
I will go try that out now!
edit:
So far so good! Thank you so much :D! And many thanks to everyone else!
I will tell news after a day or two!
Message edited by shall1990 on 12-15-2007 at 04:25:54 AM
Reply to shall1990
- 0 +
Another PSU that claims to comply with ATX 12V Ver. 2.2 specs, but doesn't. I wonder if any PSU manufacturers comply with it anymore. I guess we can just throw ATX12V Ver. 2.2 out the window.
Reply to Zorg
Try to short circuit the second power supply to get it to run without a motherboard.
------------------------------ http://img211.imageshack.us/img211/2376/anonnymousesteamsigmx2.png
Reply to scarslilpyro
TO make that more clear.....green to black....and some psu's will not run right without some load....
http://img172.imageshack.us/img172/1667/hpim1551ws8.gif
Reply to nukemaster
http://img172.imageshack.us/img172 [...] 551ws8.gif
Well if you don't know what that means, you probably shouldn't be trying it, lol (to OP)
- 0 +
I just wanted to give those curious another reason why someone would want 2 psu. I am upgrading my rig, so I am trying to keep as much as the old stuff as I can, so I can put my money twards the new stuff I need. I have a bunch of psu's, but they all tend to be smaller because they are from sff (small form factor) rigs. The only one with SATA is 110w so I want to have that run the drives, and a bigger one run other stuff.
Reply to kherova
- 0 +
Also, I know the war in this tread is over, but I wanted to throw in my 2 cents because this is my second post to the forum. :) Seems to me that people shouldn't be too concerned about people who don't have many posts giving their opinion. Everyone is entitled to what they think even if they only post one comment in their lives. You may not lend much weight to their opinion if you feel they haven't earned it (and that is your right), but that doesn't mean they don't have a right to express it. It is a dangerous slope when you start holding a price for admission to be legitimate at a certain amount/quality of posts.
I can understand about the desire for a sense of community, but it has to balance with the needs of casual posters. If they only post one thing, but it helps someone out 3 years down the line, then the post has purpose. As long as you have a core set of users doing activities you believe to support your idea of community then there will be one, and the periphery of strangers won't do anything to take away from that core (will actually add some flavor to it). After all, if you just wanted was pure community, you could just im/pm your friends all day. A true community has people who don't act or feel the same way you do, and you have to find a way to live with them too.
Reply to kherova
- 0 +
Yes its possible.
Message edited by ktibor on 06-02-2010 at 12:36:01 AM
Reply to ktibor
guys, come on, this is a dead thread.
Reply to shovenose
There are 1766 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 2 hours ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
