Hello
I need some help with a problem i am having with my pc and i will be very happy if someone can help me. I had bought a memory upgrade last month, first few weeks of installing the upgrade, there was no problems but after few weeks my pc started to restart for no reason and than refuse to even reach my desktop. When i took out the upgrade, the chip was very hot even though i had not used the pc much on the day.
Here are some information that might come useful in helping me solve this problem:
Upgrade: Kingston 512MB DDR PC3200 400MHz CL3 Memory Module
PC Specification: System Memory
* Supports 2 memory slots.
* Supports a maximum memory size of 2 GB (using 2 x 1 GB memory modules)
* 400/333/266 MHz
* Support only 2.5 V DIMM DDRAM configurations
* Unbuffered type support
Motherboard: Santiago (P5S800-VM)
Did i buy the wrong upgrade? Do i need a fan? Any help in resolving this issue will be great and i will be very grateful.
Thank You
* 400/333/266 MHz
Thank You
