Hi
I have a quick question, very easy to answer (for you ). I just want to make sure. I am very new to building systems and that is what I will try to do in few days, so I would very appreciate your help
The power supply that I oredered:
Corsair 520W SLI Certified Modular ATX Power Supply - CMPSU-520HX
http://www.buy.com/prod/corsair-520w-sli-certified-modular-atx-power-supply/q/loc/101/203270716.html
The motherboard that I bought:
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/product/product.asp?item=N82E16813128059
And my questions are:
The connectors that are comming out from power supply are:
24-pin power cable - that one that I will use
4-pin +12V - that that I will use
8-pin +12V - I don't need one, isn't right? I can put it on the side, right?
Another question.
The case that I ordered is:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&Tpk=antec%2b900
The PSU is going on the bottom of the case. Does the fan that is located inside the PSU should faced the top or bottom of the case?
I know those are very silly questions but just like I said I am very new to building computers and I don't have manuals yet ( hardware is on the way), and I have read the forum for a while so I know you are really experts.
I apprieciate your help
thx
Another question.
thx
