I seem to have a problem that quite a few people have mentioned (but no working solution has been found that I can find).
After plugging everything in and then flicking the power switch on my power supply (not on the PC box) all the fans start up but it seems like nobody is at home. No beeps and only one green light on the box that doesn't flash or flicker. Monitor doesn't register anything and no POST or bios information shows up.
My specs are:
Asrock AM2NF3-VSTA Motherboard
AMD Athlon 64 X2 4600+ Windsor 2.4GHz
ELSA GLADIAC 776 GT AGP 256MB (7600 GT)
1GB PGI DDR2-667 RAM (667MHz)
1GB DDR2 PC2-6400 Elixir (800MHz)
Western Digital 160GB HHD
ENERMAX EG365P-VE FMA 1.3 ATX12V 350W Power Supply
I bought the board because my AGP is still strong enough for what I need but I wanted to start using a 64 bit processor. I've tried switching RAM sticks and slots and using only one chip and but no change. The power seems to start up as soon as the PS is switched on. Holding down the power button on the box does't shut it down and the reset button doesn't seem to have any effect either.
Any help would be appreciated!
Message edited by HG_Raigon on 01-03-2008 at 01:42:40 AM
Sponsored Links
Sounds like something's not connected quite right (turning the PS on should NOT turn on the fans, etc). Try a bench test: take the MB out of the case and install only the CPU, CPU cooler, one RAM DIMM, and the video card and power supply (make sure the MB is sitting on something that won't short it out, like a big piece of cardboard). Turn on the PS power switch; one or more LEDs might turn on, but no fans should be running. Use a piece of conductive metal (like a screwdriver blade) to momentarily connect the two power switch pins on the MB's header -- this should turn on the power to the computer and get the fans spinning, etc, and show the start-up messages on the video monitor.
If it's not a connection problem, I'd suspect your power supply, especially as older power supplies like yours (besides slowly declining in their power over time) often don't have enough +12V power for modern CPUs and graphics cards.
Message edited by Mondoman on 01-03-2008 at 09:47:24 AM
Reply to Mondoman
Let CPU, GPU and RAM (one stick) installed. Remove the HDD or any other PCI peripherals. Remove all USB devices.
Check BIOS jumper.
Reply to slicessoul
that happened to me once. i had a power supply fail, bought a new one, put it in, and the fans would come on when the ac power was switched on to the PSU. returned the psu for a different brand and everything worked ok. i would try a different power supply.
Message edited by coldneutron on 01-03-2008 at 07:21:53 PM
Reply to coldneutron
Disconnect the power switch from the mobo. Like Mondoman said, turning on the PSU switch should not turn it on; if the PC's power switch is shorted though, it will.
Particularly if your eyes are no better than mine, double check that you have not put the Power LED connector on the Power SWITCH header.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > New mobo power up issue
There are 1138 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
