I have a DFI Lanparty DK and a Q6600 HSF, I mounted the motherboard in my p182 case but notice 1 of the 9 screws would not reach the case bottom screw. Is this okay? it's the screw located near the pci-e card on the edge center. All the other 8 screws are securely in place.
Also I mounted HSF after when the mobo was already mounted. I tried to do the cross star pattern by first pushing one of the HSF pins in and hearing it snap in place. Then when I tried to do the opposite one it was hard to push in.. So i pressed pretty hard and notice the motherboard bending, and hearing some bending noises u know the crackles.. Now i'm a little paranoid that I might have damaged the Mobo.. So my question is.. is the MOBO pretty sturdy and can take some flexing?
In the end when i pushed 2 opposite pins in at the same time it locked in placed nicely w/o using much force.
Thanks in advance!
Message edited by Jake_Barnes on 05-05-2008 at 02:00:38 AM
This topic has been moved from the section CPU-Components to section Overclocking by Jake_Barnes
------------------------------ The Edge... There is no honest way to explain it because the only people who really know where it is are the ones who have gone over. - HST
Reply to Jake_Barnes
A mobo can normally take a lot of force, so as long as it boots up normally and all, I wouldn't worry. And 1 screw won't make too much of a difference either.
In the future, it's recommended to put on the heatsink first before putting the mobo it. Those pushpins are quite stubborn.
------------------------------"Nvidia, the Way It's Meant to be PAID Played! - Corrado
*Lesbian Lover Club* - founder Assman
Reply to Evilonigiri
