Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Better to switch to built-in sound chip ?
Forum Motherboards & Memory : General Motherboard - Better to switch to built-in sound chip ?
Hi ...
Now I'm using a PC with Gigabyte 945P-S3 rev.3.3 with CORE 2 Duo 2.133GHz (E6420) and Geforce 7900GT..2GB of 667MHZ DDR2 main memory...With SATA II Maxtor 160GB storage..
I use for sound the "ancient" Creative Sound blaster 5.1 live (S0100) chip from Creative...with discountinued driver support from long time ago from the company...
My question is that : Will I lose in terms of performance when I take off the PCI Creative sound card to replace it with the built-in one in my Gigabyte board or not ? in terms of games,compatibilty,and general performance ?? I use both XP prof. and Vista 32bit HomePremium ? Does it worth it ? is it better to change to the built-in sound or not ???
Sorry if this was not the correct place to put my thread...
Sponsored Links
Sound should be at least as good. The best way to determine sound quality of anything is to listen to it. Sound quality is very subjected, what sounds good to me may not sound good to you so try it. Internal sound card will use more resources but not enough to be noticeable on that build. Just be sure to remove the drivers for the sound card first and enable the onboard audio in the BIOS
Reply to g-paw
Thanks for you reply....I will try it ..by the way,I can see 2 files in the drivers page in gigabyte website one is obvious which is the driver and 2nd on is microsoft audio bus or something ..should I install the latter before the driver or not necessary....???
Reply to mahanddeem
- 0 +
Not really sure but if it were me and the Microsoft audio bus driver is installed and the one on the site is newer, I'd install it. If it's not installed, I wouldn't.
Reply to g-paw
- 0 +
The intel HD audio (onboard sound) is vastly superior to that old card.
Message edited by skittle on 01-06-2008 at 04:27:12 PM
Reply to skittle
Thanks for your reply....Greatly appreciated..
Reply to mahanddeem
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 EChiasson won the Freshman badge
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
