Hey all. I am wanting to install an aftermarket VGA cooler on a 8800gt. My main question isnt what cooler to buy but exactly how to remove the old stock cooler. As I look at the the pics of the card, I wonder do I need a specific tool that will remove the screws that are used to fasten the stock cooling? Because it doesnt look like a typical phillips head screwdriver will do the job.
Also, as far as attaching new heatsinks to the gpu, what compound do you recommend? Do you use an adhesive such as the kind Arctic silver makes?
I am thinking of using the Thermaltake HR03 or Zalman Vf900.
I read a guide on installing the HR903 but it did not talk at all about what adhesive to use to adhere the sinks, or exactly how to remove those pesky screws.
If you go with a different cooler like the Zalman, I think you have to buy separate heatsinks for the MOSFETs and you'll have to find some kind of adhesive solution.
Message edited by kpo6969 on 12-13-2007 at 09:50:13 PM
------------------------------ P35-DS3L Rev 2 bios F9C l E8400 @ 3.6Ghz @ 1.232v l OCZ Vendetta 2 /LGA775 Bolt-Thru l 4GB G.Skill 8800PI@1000mhz 4:5 @ 1.87v l WD3200AAKS 320GB l Evga 8800GTS 512 l X-Fi Xtreme Music l Corsair HX520 l Antec Sonata III 500 l Vista32 SP2 l Win7 X64 7600
Reply to kpo6969
