Tom's Hardware > Forum > Overclocking > General Discussions > Simple Case Cooling Question:
Forum Overclocking : General Discussions - Simple Case Cooling Question:
Would 2 of these super cheap 80mm case fans: http://www.newegg.com/Product/Prod [...] 6835150007
Outperform a single high performance 120MM fan? http://www.newegg.com/Product/Prod [...] 6835185060
Thanks.
------------------------------ E8400 3.6Ghz | 4GB DDR2-800 | HD4870 | 780GB HDD Space | VX550W | WinXP | Win7-64 | Ubuntu Studio 8.10
Sponsored Links
The 120mm produces almost double the air flow of two of the 80mm. So, no IMO.
Reply to Lord Gornak
Is this some kind of test ?
The specs.
80's- 31.73cfm x2=63.46cfm
120-110.31cfm
uhhhhhh lets see...the 120 flows more.
Reply to rsetter1
I already noticed that... but what conditions are they using? Why should I trust something the company that makes it says? Instead of being an ******* just answer the question.
Reply to doomsdaydave11
It's not about trusting what they say, it's the physics of surface area. Larger fans push and pull more air at lower speeds that smaller fans do at higher speeds.
The 120mm Scythe you used as an example outputs 110.31cfm.
This 90mm Scythe: http://www.newegg.com/Product/Prod [...] Tpk=scythe has a max output of 55.5cfm, half of what a fan that is 30% larger pushes.
The larger fan will push more air, and likely be quieter than having 2 smaller fans. So the 120mm is a win-win situation. Not to mention it could possibly draw less power too (not like that's a very sizeable draw anyhow).
------------------------------ i5-750 4Ghz @ 1.32V / Gigabyte GA-P55-UD4P / Xigmatek HDT-S1283
2 x MSI GTX 260 Core 216 SLI (655Mhz) / 4GB GSkill DDR3 1600 9-9-9-24 @1.5v
2 x WD Caviar Black 1TB / Thermaltake Armor BWS8003
Win 7 64bit / Antec TPQ-850 / 3dMark06 24621
Reply to jerreece
There are 1199 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
