hw_user :
Some time I watch Video over Internet or Video from friends. But the sound volume is low. I have adjusted my laptops volume to max. I still cannot get a good level. An external amplifier is not always available. I think this may the original clip was prepared with a low audio level. Is there any good software that can help. Preferably free and not involve touching the original video file (such as re-encoding).
I'm replying to this old thread.. But I found a free audio amplifier or an equalizer software which is useful for everyone (Well mostly..):
-Softwares-
EqualizerAPO: http://sourceforge.net/projects/equalizerapo/
Requirements:
- Windows Vista or later (currently only Windows 7, 8 and 8.1 have been tested)
- Sound card driver must support APOs (this includes most onboard sound drivers)
- The application must not bypass the system effect infrastructure
(possible by using special APIs like ASIO)
Simple GUI program by Znuff to put inside one of the sub folder:
32bit version: https://dl.dropboxusercontent.com/u/120650/EqAPO/eq-con...
64bit version:https://dl.dropboxusercontent.com/u/120650/EqAPO/eq-con...
How to use by Znuff:
1. Download EqualizerAPO software first
2. Edit the default config file ( \Program Files\EqualizerAPO\config\config.txt ) to read something like this:
Preamp: 0 dB
Include: eq.txt
3. Download the Simple GUI program and drop in the config directory (again, \Program Files\EqualizerAPO\config\)
4. Start the GUI and play around with the settings. You should notice a change in the sound as soon as you move the sliders.
Have fun guys! If you want more information, you can check out his website at:
http://linge-ma.ws/equalizer-apo-config-gui/
So thanks to the great Znuff well he rocks and Ohhh yeahh see ya!
