I have a Asus P5W DH Deluxe homebuilt. I had a 550W Antec power supply along with my P180 Case.
While my computer was off, I returned home and could smell electrical burning. I traced it to my computer. It would not power on. I took it apart and it was the power supply. You could smell the power supply......nasty smell.
I installed a new power supply and put things back together but the computer would not start. The power supply works, you can hear all the fans running but it will not post to the bios?
I took it back apart, pulled the onboard battery and reset the bios. Put everything back together, same thing..................just sits there with all the fans running full speed but will not post
Any idea what i should be looking for? I really can not afford to start throwing new parts at it
Thanks for any help. And thanks for this laptop I am using
Lenny
Lenny
