Hello all, I'm running a P5N-E sli mobo and Dual core 2 e6400 with 3 gig of ram at 667 pc2-5300 and was wondering about my mobo temp its running at 39c cpu is rather good at 27c was wondering if my mobo temp is normal or what? I have a FS-C77 cpu cooler running at 2220 rpm's atm...Also around 5 other 80mm fans also a 8800 GTS 320mb xfx OC'ed also Hiper-R 580w PS.. i thought i might give you my PC spec's since everything that generates heat might be a problem.... Remember im wondering about my mobo temp is it fine or what could be fixed here? Thanks...
