Tom's Hardware > Forum > Homebuilt Systems > New System Build > Power supply question
I have rebuilt my computer. using these parts
MSI P6N Diamond
Intel QX6700
2 x TWIN2x2048-8500C5D (4 Gig) With Corsair cooler
1 x EVGA 8800 GTS (possibly will add a 2nd for SLI)
1 x samsung OEM DVD writemaster
1 x GGC-H20L blu-ray/HD-dvd DVD-burner
2 x Samsung 250G drives (dont remember the model)
10 x WD75000aaks
Promise supertrak EX16360 (raid controller)
Creative X-FI platinum
2 x BDU-350Sata hot swap cages.
I was considering a thermatake 1000W w0132ru?? is this too little?
Sponsored Links
Will add water cooling by koolance within the month. Forgot to add this.
Reply to scmeis1
- 0 +
No its even more than enough
consider OCZ PROXSTREAM 1000W too, its a very good PSU
------------------------------ Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
Sh it dude what case are you going to put that in? 12 hard drives and 2 burners?
Have you thought about maybe 2 machines to do this? have your RAID in another tower?
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
- 0 +
COOLER MASTER Stacker 810 RC-810-SKN1... Is my case, It is perfect for everything, lots of room for Water cooling. The 2 bpu-350SATA cages take up 6 x 5.25 slots. My 2 other hard drives have their on 5.25 spots, like to keep my OS seperate. The last item is the 5.25 creative device for external connections. All total 11 spots are used. This case is perfect and very roomy.
Now I am re-thinking my mobo choice. So Far, I am not having any luck OC my board. I can not get it to even display the bios and I haved tried everything. Frustrating, i should of went with my gut and not bought the P6N. I just needed the 4x 16x PCI-e slots. I rethought that also and bought a new raid card the one listed above, I was using a rocketraid 2320, which I needed 2 of those.. This card has multilane sataII to support 16 sata drives. Then I sold my hauppauge wintv pvr-500 MCE due to lack of PCI and PCI-E slots.
Now I am really re-thinking the mobo. Any suggestions, I probably will not SLI now, but still need the 2 x PCI-E (16 and 8). At least 1 PCI for my creative card and has to overclock well for my quad core. No Wifi necessary, I have gigabit through out my house.
Message edited by scmeis1 on 12-09-2007 at 11:57:04 PM
------------------------------ CCNA, CCIE (written), CCIP (QOS, MPLS, BSCI)
CQS-CWLSS, CTE-CWLSS, MCP, Solaris 10
Reply to scmeis1
http://www.newegg.com/Product/Prod [...] 6813128067
OR
http://www.newegg.com/Product/Prod [...] 6813128064
both great boards and not expensive.
There is ALOT of complaints about those BDU-350Sata's on newegg... I think i may have to look at something like this for my server, but ive got an Antec Titan that has the slide rails that may not fit well. Plus i notice it only has 2 SATA power on the back and 3 Molex is it possible still to have 5 SATA power drives connexted.?
Reply to chookman
- 0 +
yep. I have had that for well over a year. I just added the 2nd one this week, I like them. You just have to maintence them, like most server type of devices, they need to be kept dust free. I rarely care what is said on newegg. I look for certain things only in comments, otherwise I chalk it up to lack of knowledge.
I can not use either of those boards, they are x16 and x4 on the pci express slots. I need at least an 8x along with the x16.
Message edited by scmeis1 on 12-10-2007 at 12:46:01 AM
Reply to scmeis1
- 0 +
I dont see the point of having that many HDDs in one system...
First the heat generated inside the case from that many HDDS should be insurmountable... Proper water cooling may bring it back to legitimate temps, but offloading the HDDs to an external case properly designed for the specific task is a superior option. Let alone a second CPU on older hardware running Win2k ( or Win2K3 ), over Gigabit...
That many HDDs in a single case seems like a bad idea on many levels...
-Dejunai
Reply to Dejunai
- 0 +
That is a matter of opinion, where space is a concern. This has nothing to do with my topic, of a power supply and now on to the motherboard. This case is very well cooled, and even without water cooling is lower then I would hope for.
Reply to scmeis1
An x38 chipset board would be the next thing to move to then to get the extra pci-e lanes. ASUS P5E would be a nice choice.
http://www.newegg.com/Product/Prod [...] 6813131219
this one could give you a slot allocation issue... youd have to check on that.
Other than that you would have to move to a NVIDIA based board which from most ive heard have compatibility issues in a number of areas.
Reply to chookman
- 0 +
Nice board. I finally decided on the Asus X38 maximus formula. It had the right growth potential, friendly overclocking, and just the right amount of PCI-E and PCI slots for me. http://www.asus.com/products.aspx? [...] odelmenu=1
I thank you very much for you input! Now I just hope my 8800GTS works on a crossfire board LOL.
Reply to scmeis1
I dont know wether to take that seriously or not. YES it will work... but LOL if you were joking?
Reply to chookman
- 0 +
Oh I was serious, I hope my 8800GTS works with my new board. I always wonder about that.
Reply to scmeis1
There are 716 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
