Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » AC 7 Freezer Pro Lapping Problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : AC 7 Freezer Pro Lapping Problem
Profile: journeyman
More Information
All ready to lap my HSF and CPU today and I discovered that the pushpins on the AC7 pro are riveted on and that they actually hang BELOW the HS base - thus making lapping very difficult (if even possible).
Has anyone heard of a solution to this problem. If not I'll have to improvise, but was hoping to get some advice.
side note: both my e4300 IHS and my AC7 base are slightly concave (used a razor blade)... the pattern of the paste after I removed the HSF also confirms this observation...
P5N32-E-SLI, e4300@3.2, 4x1gig tracers 1:1 , 8800gts-320 OC ?/?, antec 850w psu, antec 900 case
Vista64 Ultimate
Related Pr oduct
Profile: addict
More Information
Take a piece of cut glass, like 2 bucks at a hardware store, take it home with you, and put it on the face of the heatsink, see if its level. If it is it doesnt need to be lapped, i have this cpu cooler, and mine was nice and straight.
Q6600@3.2g, 4 gigs 2x2 ADATA Pc 6400, XFX 8800 GTS 512 G92, GIGABITE GA-P35-DS3L, ARCTIC COOLING FREEZER PRO 7, Antec 900 case, Antec 500 earthwatt p.s. 27.5" Hannspreee monitor (oh yeah!!)
Profile: journeyman
More Information
Quote :
Thanks, that's good advice and I'll try it out of curiousity, but I can tell that it is concave, although only slightly. Combined with a concave IHS on the cpu this creates a nice fat air pocket (or pocket of heavy TC) just above the center. Again, I confirmed this by looking at the TC pattern after removing the HSF.
Vista64 Ultimate
Profile: Faithful Poster
More Information
I did mine. I took a small wood block the size of a small box of matches and wrapped sand paper around it. Shes flat and shinny now.
Profile: journeyman
More Information
was hoping there was a better way (removing clips), but that (block) idea sounds pretty good
Vista64 Ultimate
Add a reply
Google Ads
