Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GPU Fan Speed - is 100% possible?
Just wondering if I can turn my GPU fan speed to 100% without any problems. I turned it to 80% and it dropped like 10 or more.
Sponsored Links
Yes, if you cut/remove the wire that gives it the RPM reading, the fan will usually run at 100%. This depends in the card/manufacture, etc.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Or you can use rivatuner and set your fan however you want.Even profiles.
Reply to uberman
Well i have a 8800 gtx ko3 version, i just went into the nvidia control thing and did it from there. Just wanted to make sure i wasn't gonna blow the thing up if I set it to 100% lol
Reply to Trunkz_Jr
There are 1151 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
